07-25-2018, 08:55 AM | #1 |
Light ?
Putting a 68 back together. Changing all turn signals to led. 1st ? B-4 i start to troubleshoot front turn signals. Does bed with rear lights need to be installed b-4 front will work, or r they separate? Tks.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
07-25-2018, 12:52 PM | #2 |
Msgt USAF Ret
Re: Light ?
L E D s are not dependent on heat resistance to flash as long as the correct flasher is used , and the polarity is maintained, and you are correct in that the front's are separate from the rears as far as the wiring. They are connected by the TS switch LF/LR RF/RR so the fronts or the rears should not have to be installed for the others to work. Unless the flasher unit demands it. The lights should illuminate anyway with correct wiring and good grounds.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
