Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-19-2018, 09:54 AM   #1
HRD
10SI alternator DA plug wire colors reversed?
I'm in the process of converting a 6 volt truck over to 12 volts.
I'm going with a 10SI alternator for a 78 Camaro.
I picked up this DA plug at the same time I picked up the alternator.
Since this plug will only plug into the 1 & 2 socket on the alternator one way. It throws your RED wire on the #1 pin and WHITE wire on the #2 pin.
Isn't that REVERSED? Are am I missing something?
By all that I've studied and looked at it has anyway.
My truck is a 51 GMC with a 62 Chevy 235 motor. The fuel gauge and heater are currently unwired until I decide which route I'm going with them. I have a light and volt meter wired in.
Hollis
HRD is offline   Reply With Quote
Old 08-19-2018, 10:50 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 10SI alternator DA plug wire colors reversed?
looks righ per diagram. Why not wire it with the three wire setup as designed?
Old 08-19-2018, 12:55 PM   #3
HRD
I am wiring as it's designed with that #2 wire going to the battery. I was just using that drawing to show that the red wire is suppose to be on the #2 prong and using those plugs would reverse the wires on the alternator placing the red on the #1 prong & white on the #2.
I just used a small blade screw driver and reverse the wires in the plug so that they do connect up to their right prong. White - #1 & Red #2.
I don't know what effect it would cause to have the #1 prong going to the battery and the #2 to your light and ignition switch but all the drawing I've been looking at show that is reversed using that plug.
Hollis
Old 08-19-2018, 03:07 PM   #4
Warrens69GMC
That diagram has White-1 and Red-2
What you might be seeing is where they have it going to the power post on the alternator.
