03-04-2019, 12:18 PM | #1 |
1970 c10 voltage regulator wiring
I removed my voltage regulator to repaint and clean up my radiator core support. I committed a crime. I did not write down the wiring sketch. Now everything is installed and I am only getting 12.4 volts at the alt. when running. Is it a ground problem or something else?
03-05-2019, 05:16 PM | #2 |
Msgt USAF Ret
Re: 1970 c10 voltage regulator wiring
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-06-2019, 12:04 PM | #3 |
Old member
You may just need to scrap a small amount of paint off to get a good ground where the regulator is mounted.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
