03-11-2017, 06:25 PM | #1 |
Is this the stock radio amplifier?
So driving home last night, I hit a bump and out popped this from under the dash. I'm assuming it's an amp due to the heatsink and can only assume it's from the old radio? There's a modern radio in the dash now. Just curious as I'd either like to find it a home or remove it if it's unnecessary. I also searched via the part number and came up empty.
The PO also had an alarm installed, found the main unit under the dash and also a horn under the hood. I'm a big fan of having only the necessary wiring, not loose ends like you can see in the upper right corner. I hate tape over ends like that! This truck runs the chassis as a main ground so I'd hate to accidentally short anything out. Thanks in advance! |
03-12-2017, 12:34 AM | #2 |
Re: Is this the stock radio amplifier?
That is for delay wipers.
03-15-2017, 05:01 PM | #3 |
^x2
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
03-17-2017, 07:37 PM | #4 |
Thank you!
So I've searched for a home for this and can't find a spot. Is it just bundled up there or does it have an actual place it's mounted? Much appreciated! Rob |
03-19-2017, 10:10 AM | #5 |
What year is the truck?
03-19-2017, 02:41 PM | #6 |
