06-12-2017, 10:38 PM | #1 |
best plan for painting over rust and old rust converter
I am redoing the frame of my suburbans original back seat, over the years the seat spent alot of time stored outside. 5 years under a large pecan tree caused pitting on the lower frame and back.
Over the years i put many layers of paint and rust converter on it. I have stripped all the paint but the rust converter is really sticking, and some of the rust is deep and hard to get out. I've done a few acid washes, lacquer thinner, sanding 50 grit, wire wheel , files, etc. There is still a large amount of pits, rust and old converter. I want to paint this frame as a temporary measure hoping in a few years get it professionally cleaned,blasted or dunked. I had planned to paint the frame with eastwood 2k aerosol epoxy but with the amount of non bare metal i will have, i think the adhesion of the epoxy would not be good. any ideas what would be a good way to go to protect the frame and have it look decent until i can get done right.?
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
06-14-2017, 10:00 PM | #2 |
Re: best plan for painting over rust and old rust converter
Just get it done right this time around. Otherwise you will be doing it again in a few years...just get it blasted and shoot epoxy.
'72 Chevy K-20 Crate 350, SM465, 4.10's |
06-14-2017, 10:15 PM | #3 | |
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
06-16-2017, 10:56 AM | #4 |
i ended up spending alot more time scrapping and sanding, got 95% of the rust and gunk off. there were only a few spots of scale and pitting left, with no loose stuff.
I had a can of spraymax and used that instead, after 24 hrs. it seems to adhered well to the non bare metal spots. I think i got my seat frame protected enough to store outside .
06-16-2017, 01:39 PM | #5 | |
