07-16-2018, 08:02 PM | #1 |
2' lift on a 69 4X4
What is the best way to get a 2' lift on a 1969 4X4. Lock kits or springs? thanks Rick
07-17-2018, 06:30 AM | #2 |
Re: 2' lift on a 69 4X4
2’ lift?!? Gonna need a whole lotta spring!!!! I’m assuming you meant 2”, which can be done with springs, or a longer shackle with a zero rate. Or even a long add-a-leaf to the pack.
07-17-2018, 11:14 PM | #3 |
I’m doing a 3” on my blazer. I got everything from ORD with a shackle flip and new springs.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
07-18-2018, 04:47 PM | #4 |
20' Daredevil (Ret)
If you meant 2", I installed 2.5" Skyjacker Softride springs on my K20 several years ago (front only). No complaints.
If you actually meant 2'..... I got nothin.
07-18-2018, 07:28 PM | #5 |
I'd do all new softer riding springs like Softrides or EZ-Rides. Reverse shackles will give twice the lift you want. I did 4" springs on front and on the rear I did Add-A-Leaf & 2" block. It doesn't even look like it has the 2" blocks, so Add-A-Leaf doesn't appear to have lifted it any. Maybe my original springs are just that bad. I'm wishing I bought new springs
07-20-2018, 08:27 AM | #6 |
My truck is a 69 GMC half ton. I used the 2” ez rides on mine. For a lifted, solid axle truck, it rides pretty well. I drive it daily and have gotten quite used to it. It has 33 inch tires on it. Here is a pic:
