Old 08-01-2020, 09:52 PM   #1
BAD1916
Junior Member
TH400 whining
Thought Iíd post this up before I yank my trans...
I have a 71 GMC 2500 454(original 402 block was cracked) with a TH400 from a 67 chevelle( donít know if that matters any). This setup has been running for 4 years and this Is my normal driver. Anyhow, a few weeks ago I left my house and I could hear the trans whining so I pulled over and put it in park. I didnít hear anything while in park so when I shifted back to drive the noise was gone. I assumed it was a fluke. Fast forward a few weeks and this morning me and my boy are headed out to go fishing, got the kayaks all loaded up and while enroute the whining started again but this time it didnít stop. I tuned around to head home and when I got stopped at a light the Burb would hardly move. So called AAA and got tow hooks instead of fishing hooks. At home the truck seems to shift fine and goes in and out of gear fine though I have only moved parking spots.Sorry for the long winded post and if youíve read this far do you have any thoughts on anything to look at before I pull this thing out? Thanks in advance for any help.
Bryce
BAD1916 is offline   Reply With Quote
Old 08-01-2020, 09:57 PM   #2
BAD1916
Junior Member
Re: TH400 whining
Forgot to mention fluid level is good and no burnt smell. I also checked the vacuum modulator connections and all is connections are good there.
Old 08-01-2020, 11:41 PM   #3
HO455
HO455's Avatar
Re: TH400 whining
You might try replacing the filter. It has never worked for me but you might get lucky. Not trying to be funny just stating the facts. Plus once the pan is off you might see something that could be fixed. Like loose bolts in the valve body.
After replacing/rebuilding a TH400 every 18-24 months in my GTO for 12 or more years in my experience once they start slipping too much to move the vehicle they are toast. They might work for a little while when cold but once they warm up your stranded.
Best of luck to you.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 08-02-2020, 01:13 AM   #4
BAD1916
Junior Member
Re: TH400 whining
Thanks for the info. That is kind of what I figured but I thought Iíd get some thoughts from people with more experience than myself. I will drop the pan and see what it looks like. The filter was replaced less than 10000 miles ago but wouldnít hurt to try.
Old 08-02-2020, 02:58 AM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Re: TH400 whining
Loose pick-up tube causing air to enter causing whine and low pressure screwing up engagement?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.Wrecked 7.2020 after 24 years service.
WorkinLonghorn is offline   Reply With Quote
Old 08-02-2020, 07:20 PM   #6
BAD1916
Junior Member
Re: TH400 whining
When I pull the pan I will look for that. Thanks for the suggestion.
Bryce
Old 08-02-2020, 10:02 PM   #7
clinebarger
Re: TH400 whining
I've seen more than a few Felt style TH400 filters stop up, Alto sells a Stainless & a Brass screen type filter.
clinebarger is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
