05-30-2003, 12:27 AM | #1 |
Progress = 0%
Slammed67 Enterprises :) x-member mod.
Well, I've almost got my cross member modification done!! Just need to paint the parts and install them on the truck. Here are a few pics. Click on the link below for the whole story!
Project: X-Member (Oh, by the way, right now there is just a block of wood under the bag to hold it up. I still need to make a lower cup to correct the angle of the lower bag plate......... but you get the idea)
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
05-30-2003, 01:05 AM | #2 |
Wow good job, let us know how it works out. That would be very interesting to see if it does work out. Cheap mods are the best........
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
05-30-2003, 12:44 PM | #3 |
Slammed- how do you mount the bag to the top mount. The top mount is welded in place right? Besides that nice work. Nice welds too. Keep of the good work. Hopefully buying my plasma cutter today then I can show you my crossmember build up.
05-30-2003, 01:00 PM | #4 |
Progress = 0%
There are two bolts that attach the bag plate to the cross member. However, they aren't shown in any of the pictures.
The bag is attached to this plate as shown, and then that plate bolts to the cross member.
05-30-2003, 01:24 PM | #5 |
Ok it all makes sense now. So you have to drill new holes in the the side of frame to mount the crossmember ?
05-30-2003, 01:27 PM | #6 |
Progress = 0%
Yeah, just on the sides though since I only moved the upper brackets forward.
05-30-2003, 01:34 PM | #7 |
NICE work dude! Its especially cool of you to document every step and share this info with everyone. Some guys would try and keep this a big "secret". Hope everything works out - I'm sure it will.
What determined how much material was cut off of the cross member?
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
05-30-2003, 01:58 PM | #8 |
Slammed, EXCELLENT!!!!! Can't wait to see it back on the truck.
05-30-2003, 02:02 PM | #9 |
very cool, keep us posted!
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
05-30-2003, 02:22 PM | #10 | |
Progress = 0%
Thanks guys!
I can't wait to get it installed. Quote:
I'll definately post some more pics with it installed on the truck.
05-31-2003, 02:56 AM | #11 |
I Love This Stuff!
Sweet man, sweet!
My Rides 1967 C10 In Pieces for now 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
06-02-2003, 12:11 AM | #12 |
Progress = 0%
Well, I got the cross member bolted in the truck today (6/1/03). I just had to drill new holes in the side of the frame to line up with the new upper a-arm bracket locations. I noticed one possible clearance problem with one of my new plates and the steering linkage, but I think a little grinding will fix that. I'm gonna try to get the a-arms and spindles intalled tomorrow evening and then I'll post some more pics!
06-02-2003, 06:16 PM | #13 |
Are you doing this with your motor in or out? Just curious. Cant wait to see the pictures.
06-02-2003, 11:20 PM | #14 |
Progress = 0%
Okay, I got the front end put back together temporarily.
The result????? Hell yeah!!!!! I just made a subtle change, but I think it looks soooooo much better! I haven't driven it yet, just reassembled it to make sure everything fit. There are no shims in the front end in these pics, so there is a lot of negative camber. Also, it almost looks like the wheels are just slightly ahead of center. But I think a couple shims in the upper a-arm will fix that. I haven't seen any interference problems. The steering shaft is a gnats ass away from the upper a-arm when the bags are dumped like in the second two pics. However, I plan on limiting the "lowness" so I can still drive the truck (slowly) when the bags are dumped, so that shouldn't be an issue. Here are some pics!
06-02-2003, 11:23 PM | #15 |
So Many Ideas, So Little Money
schweeet, for a lil' biotch like you jason!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
06-03-2003, 10:00 AM | #16 | |
Progress = 0%
06-04-2003, 02:51 PM | #17 |
Almost Satisfied
Jason, you better get your patent sent off and start selling that idea and set up....That is a hot way to go looks to me like. Great work.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
06-04-2003, 05:39 PM | #18 |
Progress = 0%
Well, I better test drive it first and make sure nothing falls apart first! Plus I'm not sure it I'd want to do it again anyway Thanks for the compliment though!
06-04-2003, 05:42 PM | #19 |
Why would you not want to do it again? All the work invovled? or just not the results you expected?
06-04-2003, 05:50 PM | #20 |
Progress = 0%
No, it worked out just like i wanted, considering the fact that I designed it as I went along It was just a tedious process.
06-04-2003, 06:19 PM | #21 |
Well since you laid out all the ground work, it makes it easier for us.
My only worry would be the a-arms. Do you think they will stand up to daily driving here in cali? You know all the pot hole filled roads and what not around here.
06-04-2003, 08:17 PM | #22 |
Progress = 0%
Well, if they hold up to Kansas City roads, they'll hold up anywhere! K.C. roads SUCK!
That is my only concern also. I'm not worried about the top ones, but the lower arms are gonna make me nervous until I get some miles on them. The welds turned out good, so I don't see why they'd give me any grief. I'm gonna inspect them after my first few test drives to see how they hold up.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra Last edited by Slammed67; 06-04-2003 at 10:52 PM. |
06-04-2003, 10:07 PM | #23 | |
Seņor Member
BTW, I'll be trying my version of this mod in the near future. I plan to go at it a little differently... we'll see how it goes. Kenneth
06-04-2003, 10:24 PM | #24 | |
I Love This Stuff!
me neither!
06-04-2003, 10:53 PM | #25 |
Progress = 0%
XXL: Thank you for correcting my grammar
