Old 06-24-2018, 10:04 PM   #1
RADustin
crossover steering pitman arm
Gents,
Working on my '76 project (in my sig) and I'm using-
-new 80+ steering box(o-ring fittings) from redhead. New sector I believe.
-Jeep TJ pitman arm(new)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
-GM 1-ton TREs (ES2234R&L)
I reamed the pitman to accept the TREs and I went to install the pitman to the box and it doesn't fit. The spline diameter of the pitman is too small for the box. The count is the same, and the 4 index teeth seem correct, just the entire broached female spline is too small by around 1/16-3/32" measured with a tape measure and compared to a stock 2wd pitman. Everything I researched said the TJ arm would fit, but it does not.
I've already built all my suspension and steering around this pitman, ofcourse I should have test fit it alot sooner but o-well. Too late, time to find something else.
Does anyone have any ideas on what pitman I can use that is the same size as the TJ but fits the steering box? Obviously I can ream the taper for the TRE if it isn't correct.
The TJ pitman is about 1 9/16 drop and 5-15/32"(1/2") c-c. See attached snips.
I appreciate any info, thanks!
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 06-24-2018, 10:32 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: crossover steering pitman arm
maybe thisll help..but youd need a 88-98 steering box...http://offroaddesign.com/catalog/PitmanArms.htm
I don't know about the jeep on chevy setup
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-24-2018, 10:42 PM   #3
mongocanfly
Post Whore
found this also.......http://www.pirate4x4.com/forum/chevy...rms-xover.html
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-24-2018, 11:21 PM   #4
RADustin
thanks.
Your links help me figure out the problem.
The pitman I got is for manual steering. I need a power steering pitman.
now to find a power steering pitman the correct sizes.
Thanks!
1949 Chevy 3100 P/U
Old 07-24-2018, 02:58 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
i used a pitman arm off of a 79 ish F150 4x4
And also got a spare that would work off of a wagoneer.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
