Old 10-31-2009, 06:21 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
White smoke on startup and tinging noise..
when i first crank the truck cold or hot blows a white smoke cloud out 1 exhaust pipe.
Has tinging noise comming from 1 side of motor
and doesnt feel like it should have the power of a 350 (myself and others agree)
played with the timing today also
which hose should be plugged, and on my carb i have 2 places for the hose, 1 taller than the other the hose is plugged into the lower port on the right side of carb.
timing is at 8* before
is this all correct???
John
1999 Toyota Tacoma 4x4
Old 10-31-2009, 06:32 PM   #2
JimKshortstep4x4
Re: White smoke on startup and tinging noise..
It sounds lkie the possibility of a valve spring that is broken and not closing the valve fully. I would try pulling the valve cover on the side where the noise is.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-31-2009, 06:58 PM   #3
oldblue1968chevy
would it smoke and ting on out of the same head reckon?
John
Old 10-31-2009, 11:56 PM   #4
mclairmo
I always thought white smoke meant you were burning coolant/water.
mclairmo is offline   Reply With Quote
Old 11-01-2009, 12:42 AM   #5
CPNEJR
CPNEJR's Avatar
it sounds like you have a leaking head gasket and some coolant is getting into one of the cylinders. I would check the coolant level and see if its low at all. I would also pull the plugs and check the oil to see if it's milky white.
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-01-2009, 02:37 AM   #6
mclairmo
My 93 Toyota pickup was blowing a lot of white smoke out the tailpipe but ran fine. Coolant level kept going down. Turns out that the head developed a pinhole in an exhaust port and was squirting coolant into the exhaust port. Had the head welded and new head gasket out on. Cost me over $2,000at the dealer.
