Old 12-08-2011, 08:34 PM   #1
Low Elco
power lock issues?
Bought an 87 swb gmc that's hard loaded, and as usual, most of it's on the blink. When you hit the power locks, a black box under the dash by the gas pedal clicks, and nothing happens at the doors. Anyone know anything about these?
Low Elco is offline   Reply With Quote
Old 12-08-2011, 08:45 PM   #2
J Knight
J Knight's Avatar
Re: power lock issues?
90% of the time when the widows or door locks dont work its either the switch or the motor/actuator. Its always possible it could be a broken wire or a burned plug.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-09-2011, 06:51 AM   #3
turner16
the noise is the relay. If it is a wire issue it will be where it goes through the doors.
I would check the back of the switches first.
turner16 is offline   Reply With Quote
Old 12-09-2011, 08:16 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
my 88 had issues with the windows/locks when i bought it
found cracks in the wires in the drivers door tube
that and no motors were ever put in the back doors lol is a big one
changed to manual cranks,was going to take powers out of the 89 but didn't
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-09-2011, 11:14 AM   #5
ges55
BLACK SATIN
ges55's Avatar
Since the relay is clicking, your switches are probably ok. You can get the actuators on Ebay. I got 2 for $50. If your switches aren't making the relay click in both up & down modes, you can pop them out, pry them apart & clean them out & alot of the time that will make them work. Also, sometimes there are rust issues in the actuator linkage that can cause the actuator to not work & that can be fixed by removing the door panel & spraying lubricant on the rusty area. Just follow the linkage down from the lock button. Good luck.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
