Old 03-05-2018, 03:31 PM   #1
Willie Makeit
Willie Makeit's Avatar
Porterbuilt Control Arms & Bumpstops
Gents
What are you guys using for bump stops on the PB control arms for stock cross-members?
Photo's are a plus!
Thanks!
Willie Makeit is offline   Reply With Quote
Old 03-06-2018, 12:52 PM   #2
Willie Makeit
Re: Porterbuilt Control Arms & Bumpstops
so no one is using a bump stop with PB arms on a stock cross member?
Old 03-06-2018, 01:07 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Are you talking the upper or lower arms?
My bagged and extreme static dropped trucks have the bumpstops removed.
Keith
Convert to disc brakes.
Old 03-06-2018, 03:37 PM   #4
Willie Makeit
I'm not particular which arms functions as the "stop" mechanism but it appears the lower arm bottoming against a stop attached to the cross member would be easiest. Just looking for ideas on how others have achieved this.
What i am trying to achieve is to set my full dump motion to dead-head against a hard stop in case of sudden/catastrophic air loss and not put the front tire into the stock GM inner fenders resulting in bad outcomes.
Old 03-06-2018, 04:44 PM   #5
lolife99
lolife99's Avatar
It would be easiest to build a bump stop bracket off the crossmember spring pocket. Then attach a rubber stop to make contact with the lower control arm.
Energy Suspension sells many different sizes.
Keith
Old 03-06-2018, 05:28 PM   #6
Willie Makeit
I agree. what I am having an issue with is with the PB arms being tubular structures, there is not a good place directly under the crossmember / spring pocket to have the stop come in contact with the lower arm.
Before the PB arms I had such a stop in place. it was attached with one of the bolts that held the air bag upper bracket in place and it contacted the OEM stock arm on the flat where the OEM bump stop once resided. That's not possible with the PB arms due to how they are constructed, thus my inquiry of what others have done.
thanks for the feedback!
