Old 02-11-2011, 12:33 PM   #1
chevyguys
I Got it BAD!
chevyguys's Avatar
Jeep Door Stops
Anybody know if the jeep door stops are available new. Part numbers?
Build Thread: http://www.chevyguys.com
chevyguys is offline   Reply With Quote
Old 02-11-2011, 01:28 PM   #2
k1rodeoboater
Re: Jeep Door Stops
I'd be willing to bet that they are. Just call up a jeep dealer and speak with their parts department, and ask them for the parts number as well as price. Make sure they're for a Cherokee and not a Grand Cherokee though.
I got both of mine out of a u-pull it place for less than $5. Make sure you get the pin that attaches the door stop to the frame and keep the original nuts. I thought I had taken those but turns out I didn't, no biggy but it required a trip to lowes to get nuts and washers in the correct size and pitch (11mm I think)
k1rodeoboater is offline   Reply With Quote
Old 02-11-2011, 01:35 PM   #3
rwolf9653
more ideas than money
rwolf9653's Avatar
Re: Jeep Door Stops
Is this what you are looking for?
http://www.quadratec.com/products/13029_900X_PG.htm
http://www.jcwhitney.com/adjustable-...d=d1202y1992j1
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 02-11-2011, 01:54 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Jeep Door Stops
According to the Persh weblink the preferred units are from a 1984 to 2001 Jeep Cherokee:
http://www.persh.org/Pickup/DoorChecks.htm
Here’s one place that sells them new for 1984 to 1996, so there are probably others:
https://www.jeepoemparts.com/1995-je...kee-parts.html
Click on Front Door, Hardware, Door Check
Old 02-11-2011, 03:45 PM   #5
chevyguys
I Got it BAD!
chevyguys's Avatar
Re: Jeep Door Stops
I am going to head out to our local Pick-n-pull tomorrow. If they don't have any I figured I would just pick them up online... Although it looks like the are about 50.00 each! WOW! Let's hope pick-n-pull has them!
Old 02-11-2011, 08:32 PM   #6
283nova
Re: Jeep Door Stops
if you mean the little plates with the nylon straps, those are not in cherokees, but they are in wranglers.
283nova is offline   Reply With Quote
Old 02-11-2011, 09:13 PM   #7
Captainfab
60-66 Nut
Re: Jeep Door Stops
Have you considered the repro's of the original door limiters? They really aren't that much $$.
http://www.classicparts.com/1960-66-...ctinfo/18-481/
I don't know if there is an advantage to using the Jeep straps versus these, but before I spent much money on the Jeep ones......
Old 02-12-2011, 12:41 AM   #8
k1rodeoboater
Re: Jeep Door Stops
The jeep ones don't let the door open anywhere close to the cowl which can put a nice dent in your doors
Old 12-14-2011, 06:03 PM   #9
Woogeroo
Re: Jeep Door Stops
The point of using the Jeep door checks on our trucks is that they will hold the door open on a hill, the originals door checks just stop it from opening too far. Well, until they wear out and break and the door slams into the cowl. The other thing is, by all accounts, it is a bolt in with no modifications required.
-W
update May 2014 :
Replacing Door Checks
That is the thread where persh's tech article got started... part numbers from 10 years ago listed in the thread.
Woogeroo is offline   Reply With Quote
Old 12-14-2011, 07:45 PM   #10
Born Lucky
Re: Jeep Door Stops
http://www.persh.org/pickup/DoorChecks.htm
Check this out. I think this is what you want.
Born Lucky is offline   Reply With Quote
Old 12-14-2011, 07:49 PM   #11
Woogeroo
Re: Jeep Door Stops
Yeah, that's posted up top there.
-W
Old 12-14-2011, 09:59 PM   #12
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: Jeep Door Stops
mine sure did, so did a friend's. I modified mine by shortening the arm 3/8" (cut and mig welded), that should be somewhere in the Persh link, also
Larry
fleetsidelarry is offline   Reply With Quote
Old 12-14-2011, 10:01 PM   #13
BMERDOC
BMERDOC's Avatar
Re: Jeep Door Stops
Dang! Something else to add to the list! Are they the same checks for the 67? I know 67 can be sometimes closer related to the 60-66s than the 72.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 12-14-2011, 11:08 PM   #14
rbar
rbar's Avatar
Re: Jeep Door Stops
I put the stock replacements in and they do a great job of keeping the door from hitting. They also keep the door open pretty well. The two curved bars on it put extra clamping forces on it when it is all the way open. I was going to go the jeep route, but since I had these sitting around for a few years, I put them in and was pleasantly surprised, especially for the $8 bucks or so that they cost.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 12-16-2011, 11:27 PM   #15
66_c10_tpi
Re: Jeep Door Stops
These are the Jeep Cherokee Door checks I got at the Pull a part. They are different from what Pershing shows. I haven't installed them on the truck yet but look like they will work. Not for sure if I will use the fronts, rears,or modify them to be the same length as originals.
66_c10_tpi is offline   Reply With Quote
Old 12-17-2011, 12:22 AM   #16
losthope
losthope's Avatar
Re: Jeep Door Stops
this is true if your using the front door checks from the jeep's they are shorter then the rear door checks ,if your using the rear door checks from the jeeps without shortening them they come very close like stated below VVVV and by using the rear door checks you only get one open position for the door instead of two positions that the front door checks have..
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 12-17-2011, 09:02 AM   #17
fleetsidelarry
Senior Car Nut
Re: Jeep Door Stops
did you get the thick rubber gaskets that are supposed to go between the check and the door? they help limit the amount of travel in addition to absorbing shock. on one set I got at the yard the gaskets came out with the checks, on another set they stayed stuck inside the door and I didn't notice 'til I got home.
when I did the trip to the yard I was under the impression that I needed rear checks, I now firmly believe that I should have gotten the fronts.
As a clarification, none will hit under normal, controlled opening of the door. but if you, or someone, happens to "throw" the door open, or it otherwise swings open without someone holding on, you can mar your paint. the shorter throw versions will keep this from happening.
Larry
Old 12-17-2011, 12:37 PM   #18
chevyrestoguy
chevyrestoguy's Avatar
Re: Jeep Door Stops
What an awesome, cheap mod! I really like the double detent feature.
I guess I'll have to hit the wrecking yard and pick up a pair of Jeep stops.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-17-2011, 03:37 PM   #19
66_c10_tpi
Re: Jeep Door Stops
I think I picked up three sets and none of them came out with the rubber pads. How thick is the rubber? Any pictures of the rubber pads?
Old 12-17-2011, 04:08 PM   #20
MusicMan70
MusicMan70's Avatar
Re: Jeep Door Stops
66 C-10 TPI,
Those were the ones I used as well and not the rubber type referenced in the Persh site. Those do work as shown...
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-17-2011, 04:10 PM   #21
MusicMan70
MusicMan70's Avatar
Re: Jeep Door Stops
To clarify, I used two of the one you have pictured on the left with the detent.
MusicMan70
1961 GMC Suburban
Old 01-24-2012, 12:27 AM   #22
Max1775
Max1775's Avatar
Re: Jeep Door Stops
Dude, you have got to clean out the litter box...
Max1775 is offline   Reply With Quote
Old 05-05-2014, 01:35 PM   #23
Budman56
Budman56's Avatar
Re: Jeep Door Stops
Got my jeep door stops all cleaned up and ready to install, I picked them up cheap at the junk yard off the back doors of the jeep Cherokee.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 05-05-2014, 04:08 PM   #24
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Jeep Door Stops
I used the front Cherokee door stops on my '65. They worked great and having a detente in the middle was nice when in tight spots. Downside was, the doors didn't open as far. Not a big deal but made putting larger items inside the truck a little harder.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-06-2014, 12:47 PM   #25
61K10
61K10's Avatar
Re: Jeep Door Stops
Budman--I used the jeep back door ones but i shortened them about 1/4" (just enough to re-drill the pin hole) made the door open not quite as far.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
