Old 04-29-2024, 12:55 PM   #1
Belsh
Junior Member
Core support rebuild
My core support is rotted away from under the battery, can you guys tell me if they're symmetrical in the bottom corners before I start trying to fabricate a new piece please? Thanks as always
Belsh is offline   Reply With Quote
Old 04-29-2024, 01:37 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Core support rebuild
There are patch panels available. See the thread below.
https://67-72chevytrucks.com/vboard/...rt+patch+panel
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-29-2024, 05:02 PM   #3
Belsh
Junior Member
Yeah I’ve seen the patch panels but mine is so badly damaged that they’re nowhere near big enough
Old 04-30-2024, 10:21 AM   #4
raggedjim
raggedjim's Avatar
They are symmetrical.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-30-2024, 02:16 PM   #5
Belsh
Junior Member
Good luck, Rg
Thankyou kindly Roger
Old 04-30-2024, 02:48 PM   #6
72c20customcamper
72c20customcamper's Avatar
I replaced the support on my 68 fitment was spot on . Wasn’t near as bad as yours if you want to retain the original you could use a repro as patch panels .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-30-2024, 02:58 PM   #7
Belsh
Junior Member
I would happily use a repro but the shipping cost to the UK is absolutely crazy due to the size of it, more than trebbling the cost!!
Old 04-30-2024, 09:08 PM   #8
Chevy nutcase
Chevy nutcase's Avatar
I just recently finished this task on my 66 core support to the two cornerswhere it rests on the frame. Not the easiest task without a bender/brake but it came out really well. In hindsight I might have benefitted time wise getting a new one but it's not a race and the satisfaction of a good repair offsets the frustration
Chevy nutcase is offline   Reply With Quote
Old 04-30-2024, 09:33 PM   #9
raggedjim
raggedjim's Avatar
I've made them myself in the past. Not too hard, especially if you're not too picky like me! Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 04-30-2024, 10:54 PM   #10
chevmn
Like some others, I made mine from some leftover sheet metal I had laying around. This is an area not easily seen, so wasn't too worried about cosmetic appearance, and money saved and I could spend elsewhere on the truck.
chevmn is offline   Reply With Quote
Old 05-01-2024, 08:08 AM   #11
72c20customcamper
Didn’t look at the location . There are no distribution facilities in the UK ? Seems strange that a Chinese part would have to be shipped from the US to the UK
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-01-2024, 01:02 PM   #12
Accelo
Accelo's Avatar
You may want to consider the patch panel. It completes the difficult bends at the bottom. The rest may be flatter and easier to deal with. However, with out knowing your skills and resources my recommendation may be just that, a recommendation that is based on my skills.
Best of luck.
Accelo is offline   Reply With Quote
Old 05-01-2024, 11:10 PM   #13
Smitty
Smitty's Avatar
Maybe figure out the dimensions of the patches needed. Maybe someone on here could cut them to size from a support offered on the parts page. Or someone with a semi usable one they have laying around. If not able to get all of them, you might get enough to make it easier to fabricate. Just an idle thought floating through my meager mind.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-02-2024, 07:37 AM   #14
Belsh
Junior Member
Unfortunately we have no suppliers over here of any C10 parts, I bet there are only a few hundred C10s in the whole country so probably not viable for a company to stock them.
Old 05-02-2024, 07:39 AM   #15
Belsh
Junior Member
Best of luck.
I think this is the way I'm going to do it, I'm over there in a couple of weeks so will pick one up and add it to the pile of other bits I'll be bringing home!
