01-31-2009, 11:10 PM | #1 |
Pics of Chevy HD aluminum wheels on 67-72
I bought some factory 8 lug wheels for my 67 K2500. I have seen pics before but would like to see some more. Where can I find lug nuts so that I can use the factory hub caps? Will I need to use any spacers for fitment? Thanks
02-01-2009, 05:25 AM | #2 |
the pollock
Re: Pics of Chevy HD aluminum wheels on 67-72
u can get lug nuts anywhere..
i recommend taking one off to match against the ones they have.. the typical autozoners dont know crap.. but if you go to a major chain ou'll get better arts (dicsount tire etc) .. but i wish i should score "factory" tires in my truck it think they look awesome with mudder tires pm square bodies
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 Last edited by dammitmitchell; 02-01-2009 at 05:30 AM. Reason: i really suck a typing |
02-01-2009, 11:16 AM | #3 |
1966 Crew Cab & 4X4 Fanatic
Are these the type of wheels you want pictures of ? Also a picture of one on the back of a '66. Not mine.
02-01-2009, 09:08 PM | #4 |
Those are exactly what I am talking about. And I have found the lug nuts. Or another board member found them for me. They are 1/2 -20 with external threads, these cant be found at any parts store that I know of. The factory lug nuts are metric. Good thing there is a conversion nut made.
02-01-2009, 11:53 PM | #5 |
the pollock
what size are those ?
are there "good looking factory rims in 16in? avail for 8 lugs? not trying ot hijack.. but u know more then i do
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
02-02-2009, 10:07 PM | #6 |
These wheels are 16x7. They look good in my opinion, but you know what they say about those. I picked mine up cheap so I dont have to worry about messing them up or anything. Also I have plans for new wheels in the future. I say new I would like to have a set of original wheels and hubcaps. But those are gonna cost quite a bit to get them powdercoated and the caps straightened and polished. Plus I will always have a set of winter wheels. New shiny wheels have the awesome ability of polishing any turd. And mine truck needs all it can get right now
02-02-2009, 11:26 PM | #7 |
What is a reasonable price to be paying for used rims of the style pictured above?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-03-2009, 06:47 AM | #8 |
I paid 200$ for wheels and caps. I have seen them for a little less but passed on them. Good old Craigslist has them in my area every now and then. Ebay is alot higher, more like 400 for a set. There are a few sets on there that have been polished though.
02-03-2009, 10:03 AM | #9 |
Same wheels on my 05 Dmax.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
12-06-2014, 06:17 AM | #10 |
Gripnrip
I just read your post and am putting those same style wheels on my 71 gmc 4x4. Where can I find the correct lug nuts? Thanks.
12-06-2014, 10:32 PM | #11 |
I used those on my 74 K20, and I used mag wheel collared nuts. I drilled the holes bigger, and a 1/4 spacer is all that's needed. I used 1/2 inch to put the wheels out more like stock.
Eventually I will get the center bore opened up to use a standard slip through cap like mag wheels did. |
12-06-2014, 10:36 PM | #12 |
I have those on my 74 K20. I drilled the holes bigger to use collared mag wheel nuts, and a 1/2 inch spacer. All you really need is a 1/4 inch though.
For the caps I will open up the center bore to use the old style slip through cap. |
12-06-2014, 10:37 PM | #13 |
05-03-2016, 01:57 AM | #14 |
Do You Guys & Gals Think That These Will Fit My 71 C 20
16" X 8" rims Bolt spacing: 8 x 170 Just Wondering About The Bolt Spacing Came off of a 2000 Ford F-350. Thank You Harley03joe Last edited by Harley03joe; 05-03-2016 at 02:05 AM. Reason: Add Words |
05-03-2016, 06:18 AM | #15 |
user # 2756
That bolt spacing will not fit unless you swap in 1999+ ford front and rear ends. You need 8 on 6.5".
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-03-2016, 07:23 AM | #16 |
The rims look like cragar soft 8 which are cheap.Like said in 99 ford changed its lug pattern to a metric one but the older fords 98 back will do.Gm truck you want 2010 and older 2011 gm changed the 8 lug pattern also.See if you can find the hd rims like shown or the h2 rims will work also.
05-05-2016, 02:28 AM | #17 |
[QUOTE=andrewmp6;7580836]The rims look like cragar soft 8 which are cheap.Like said in 99 ford changed its lug pattern to a metric one but the older fords 98 back will do.Gm truck you want 2010 and older 2011 gm changed the 8 lug pattern also.See if you can find the hd rims like shown or the h2 rims will work also.[/QUOTE
OK Thanks For All The Info |
05-05-2016, 02:37 AM | #18 |
No problem,If you get bored look up cragar soft 8 or d window on summit racing.They are steel rims come in a ton of sizes and bolt patterns and are cheap.
