Old 12-03-2017, 07:59 PM   #1
class01
class01's Avatar
Any pics of how you ran your air lines up front
hey guys im trying to finish up the front bags on my truck. anyone have any pics on how they ran their airlines to the front bags? thanks
class01 is offline   Reply With Quote
Old 12-04-2017, 10:57 AM   #2
Pro Performance
Pro Performance's Avatar
Re: Any pics of how you ran your air lines up front
How did you bag the front? Is it bags on a stock cross member? Aftermarket crossmember? If on a stock crossmember, I usually drill a hole in the back of the spring pocket, put a grommet, and run the line out that way. Then just follow along the frame from there, to your valves.
Pro Performance is offline   Reply With Quote
Old 12-04-2017, 07:00 PM   #3
class01
class01's Avatar
yeah its on a stock crossmember. You run it over the shock?
Old 12-05-2017, 11:01 AM   #4
Pro Performance
Here is a link to a thread and image.
http://67-72chevytrucks.com/vboard/s...d.php?t=526695
Old 12-05-2017, 03:18 PM   #5
68is4me
68is4me's Avatar
^^Did mine almost the same way. The only thing I did different was I ran my air lines on the out side of the frame. I was trying to get them as far away from any heat as possible.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 12-06-2017, 11:03 AM   #6
class01
class01's Avatar
thanks fellas. finally making some progress on my truck
Old 12-12-2017, 07:02 PM   #7
groundedc10
I ran my lines close to the same way and so far having good luck.
groundedc10 is offline   Reply With Quote
