Old 06-23-2018, 12:57 PM   #1
John H.
John H.'s Avatar
Wood floor question on longbed
Do you place bolts in all holes? I took this apart 10 years ago and vaguely remember the bolts were not in every hole.
Any pics of original wood beds for reference?
Thanks!
John H. is offline   Reply With Quote
Old 06-23-2018, 02:20 PM   #2
Old_Gold
Old_Gold's Avatar
Re: Wood floor question on longbed
Mine is not original, but i believe that there was a hole or two that were not used in the old bed
Old_Gold is offline   Reply With Quote
Old 06-24-2018, 08:35 AM   #3
custom10nut
custom10nut's Avatar
If you're referring to the Squre cut hole (on both sides) just in front of the wheelwells? I've wondered the same. My bed is unmolested so I would have to assume they were there for the numerous options from the factory. There is no hole drilled in the wood, so there's be ever been a bolt in it. The quirky thing about these trucks is that the "bosses" for every imaginable option, (to include left or right hand drive) are on all original components.
custom10nut is offline   Reply With Quote
Old 06-24-2018, 09:09 AM   #4
davepl
davepl's Avatar
Longhorn or longbed? The longhorn has extra bolts and I wound up with two kits!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-24-2018, 09:57 AM   #5
100%Chevy
Mine is a 68,C-10 longbed with the optional wood bed and there no extra holes in it.
Mike.
100%Chevy is offline   Reply With Quote
Old 06-24-2018, 11:18 AM   #6
John H.
John H.'s Avatar
I think I will leave the one bolt out in front of the wheel we'll. I remembered there was at least one not drilled. Before I drill this new piece of wood, I wanted to be sure.
Probably no harm in placing bolts in all holes, but wanted it to be like it was originally.
Dave, I may need a couple bolts from your extras
Old 06-24-2018, 11:41 AM   #7
100%Chevy
That extra hole in the bed flange may have been for the in-bed spare tire bracket.
Mike.
Old 06-24-2018, 12:57 PM   #8
FirstOwner69
FirstOwner69's Avatar
Mine had one or 2 holes without bolts on each side between the wheel wells and front bed panel that did not have bolts. I don't remember which, but I'm almost positive the two holes immediately in front of the wheel wells had bolts in them. I also put bolts in all holes when I replaced the wood. Just looks better. I ordered more bolts from Mar-K.
FirstOwner69 is offline   Reply With Quote
