Old 04-01-2018, 08:15 PM   #1
wayne4252004
wayne4252004's Avatar
Help with Carrier Bearing Angles
So, where to begin. I've had this truck for several years now and the truck has always had an issue with wheel hop. Just recently took it to a shop and they said that when the truck was built they did not set the drivetrain at the correct angles. The mechanic says that the truck drivetrain needs lowered at least 8". Can anyone help me determine if this is accurate or not? The truck is a 51 GMC body and sits on a 74 k5 frame.
Thanks,
Wayne
wayne4252004 is offline   Reply With Quote
Old 04-02-2018, 09:16 PM   #2
Myers horsepower
Myers horsepower's Avatar
Re: Help with Carrier Bearing Angles
see if any of this info helps.
http://spicerparts.com/anglemaster/measuring-angles
http://www.4xshaft.com/driveline101.asp
https://www.drivelinesnw.com/part-tr...ngle-problems/
1990 chevy Crewcab K30 454tbi/th400/np205twin stick/14bltFF,eaton posi/D60.
1972 CST K5 350/th350/12blt,eaton posi/D44
1970 K10 SWB
1970 K20 350/th350
Myers horsepower is offline   Reply With Quote
Old 04-14-2018, 05:37 PM   #3
wayne4252004
Thanks for your help. I'll try this and see what I can come up with.
Old 04-14-2018, 06:57 PM   #4
mongocanfly
mongocanfly's Avatar
drivetrain lowered 8"????.....how much angle is on your driveshaft?...drivetrain angle is different than just lowering a drivetrain...and carrier bearing is another...but all related
the 51 body sitting on the k5 frame [in itself] wouldn't cause driveline angle issues
if engine, transmission, transfer case are still mounted to the k5 frame the angles shouldn't have changed that much [not 8"] unless theres a huge lift kit involved....
and I wouldn't have thought a k5 had a hanger bearing
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
