Old 06-22-2015, 12:48 PM   #1
Custom/Ten
Custom/Ten's Avatar
What's the best way to remove primer without damaging paint underneath?
I tried sandpaper but that was scratching the paint underneath a little, maybe I just need a lighter grit. Then I tried a magic eraser and that worked really well and even took off the sand paper scratches but wàs really slow going and ate up the magic eraser pretty quick. I think those also have bleach in them which is prolly no good for paint. So I thought I just hop on and see what your guys opinions on primer removal are and if anyone has ever done this before.
Is there a special chemical that will remove the primer on top and not the paint underneath. Medium grit then light, what's the best way?
Custom/Ten is offline   Reply With Quote
Old 06-22-2015, 04:41 PM   #2
Metaldoc
Metaldoc's Avatar
Re: What's the best way to remove primer without damaging paint underneath?
Try a mild wash down reducer, but wipe on and off in the same step.( wet and dry wipes )
Metaldoc is offline   Reply With Quote
Old 06-22-2015, 04:46 PM   #3
Custom/Ten
Custom/Ten's Avatar
Thanks for the reply metal doc, I'll check that out!
Old 06-22-2015, 10:38 PM   #4
Ruscal
Clay might work if it's light over spray.
Ruscal is offline   Reply With Quote
Old 06-23-2015, 01:52 AM   #5
dakattack7
dakattack7's Avatar
Me and my buddy are having really good luck getting the random primer off his original paint '75 with wet sanding using 2000 grit. Good luck !
dakattack7 is offline   Reply With Quote
Old 06-23-2015, 08:32 AM   #6
redtailboa
try using a polishing compound , it won't harm the paint . It will make the spot look better then the other areas and end up doing the whole truck , lol
redtailboa is offline   Reply With Quote
primer removal
