Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-28-2020, 06:16 PM   #1
red69ss
Burnouts are therapeutic
red69ss's Avatar
Ignition awitch removal
I'm having issues getting the cylinder out of my 70, the cylinder is worn out I think? and the key will come out in any position so if I try to turn it and pull out the cyl the key just comes out. has anyone dealt with this before?
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 11-28-2020, 06:58 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Ignition awitch removal
https://www.youtube.com/watch?v=eJjkRzib4YQ
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-28-2020, 07:15 PM   #3
red69ss
red69ss's Avatar
Thanks vettevet , I have watched a lot of videos on it including a guy drilling it out. I have removed several of these over the years but its been a while. I think the issue is the key won't stay in the cylinder because its worn out. I will mess with it again tomorrow
1969 CHEVELLE SS
Old 11-28-2020, 07:34 PM   #4
franken
You should be able to get a new cylinder and keys from the local parts store.
Old 11-28-2020, 07:37 PM   #5
red69ss
red69ss's Avatar
I plan to replace the cylinder when I put the truck back together
1969 CHEVELLE SS
Old 11-29-2020, 10:01 AM   #6
blazer2007
My 80,s key would pull out as well but my ign. switch on the column started going so after I put a new one in the key doesn,t pull out no more, go figure.
blazer2007 is offline   Reply With Quote
Old 11-29-2020, 05:53 PM   #7
LS short box
Just a thought on replacing the ignition key and cylinder. Various vendors on this site have ignition and door locks keyed the same so you only need one key for the truck.
Old 11-29-2020, 06:21 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Ignition awitch removal
Are you using the paper clip? If the key isn't staying in try another key. Don't force it in though. Its just to have something to turn the cylinder while you push in on the button.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-30-2020, 11:36 AM   #9
NorCalC20LWB
I have a new cylinder and key you can have if you want it. PM me your address if interested and I'll get it out to you.
NorCalC20LWB is offline   Reply With Quote
Old 12-02-2020, 09:12 PM   #10
red69ss
red69ss's Avatar
hey thanks for the offer, I am going to buy a matched set with the door locks. I ended up having to drill the cylinder out . thanks to everyone for the help
1969 CHEVELLE SS
Old 12-03-2020, 11:12 AM   #11
NorCalC20LWB
Good idea, I did the same thing. Why I have an extra lock cylinder now.
Old 12-03-2020, 11:48 AM   #12
rpmerf
rpmerf's Avatar
If you get a new key cut, it should be cut to a depth standard. They should have higher notches than your current key which has likely worn out over the years.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
