Old 02-24-2016, 06:04 PM   #1
Figuarus
Figuarus's Avatar
TH400 Whining...
So, I just serviced the filter and fluid on the Th400 I have in my 64, and it has started whining when it's cold out.
After it warms up, or I drive it for about a mile or two, the whining goes away.
The filter and fluid are both brand new, and when I changed the fluid, there wasn't any real sediment in the pan.
I'm thinking front pump, but Im not too educated in this transmission to make any kind of diagnostic.
I do have a cooler on it, and the hoses are new(er) too.
Any help?
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 02-24-2016, 08:26 PM   #2
clinebarger
Re: TH400 Whining...
If it happened right after the filter change?
Double check the fluid level.
Check the plastic pick-up tube for cracks.
Check the O-ring the fits over the pick-up tube.
If no issues are found....Switch filter brands (Filtran make good ones).
clinebarger is offline   Reply With Quote
Old 03-11-2017, 04:08 AM   #3
Figuarus
Figuarus's Avatar
Ok...ANOTHER update.
My truck has been sitting for the last 4 and a half months due to a BAD engine oil leak.
Two days ago, I got down to fixing the oil leak and went to pull the truck out from under my carport. There was some SERIOUS whining from the trans when I got it to fire up.
I tried shifting into gear, but there were no gears to be had.
At first, I thought that I had lost all the fluid from the trans, but further inspection told me that there was PLENTY of fluid in the pan.
Yesterday, after letting it idle for a minute or two, the whining started to go away, and I had gears again. I took it for a drive today around town and it's now driving just fine, albeit thought I do have a whine if I manually shift into first to take off.
Is it time to consider a swap or rebuild? Is this a case of the front pump going out?
I have a lead on a 350/700r4 from a late 80s van, and it makes sense to upgrade, but if I can keep this trans alive as long as I can, that would be awesome. (I've got a weird emotional attachment to it as it came out of my dad's 71 Monte Carlo )
Thanks guys.
2013 Malibu LTZ
Old 03-11-2017, 10:09 AM   #4
68gmsee
Active Member
68gmsee's Avatar
It's been a year since the first post but did you do any of the checks that clinebarger mentioned?
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-11-2017, 11:31 AM   #5
Figuarus
Figuarus's Avatar
Yes. Used a WIX filter, checked the old filter for damage, but nothing presented itself. The fluid level is normal at hot and it's even SLIGHTLY overfilled due to a small pan leak.
We are talking 1/8th" over full mark.
2013 Malibu LTZ
Old 03-12-2017, 12:10 AM   #6
clinebarger
Sounds like your pump is getting very weak, Along with converter drain-back from worn Stator Bushings/PR valve.
If you have emotional attachments to the unit......Have it rebuilt or build it yourself, Installing a used/unknown 700R4 rarely works out.
