Old 11-17-2007, 04:38 AM   #1
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Oil filter for synthetic oil?
Should I get a Moblie One oil filter ? Or can I use my normal oil filters HP3002 K&N, Wix 51061, Purolator PureOne PL34631? I will be using Moblie One synthetic.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 11-17-2007, 09:34 AM   #2
manimal
manimal's Avatar
Re: Oil filter for synthetic oil?
WIX 51061 will be just fine.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 11-17-2007, 10:57 AM   #3
COBRO
Active Member
All you have listed are top of the line filters so let price be your guide. CB
COBRO is offline   Reply With Quote
Old 11-17-2007, 12:28 PM   #4
Jim_PA
Advance had a special around here this week, buy 5qts mobil 1 and a mobil 1 filter for 29.99 (basically, they are giving you the filter for free...). Check your local advance, they might be offering the same deal.
Jim_PA is offline   Reply With Quote
Old 11-17-2007, 07:11 PM   #5
MylilBowTie
Right turn Clyde
I just thought there were better filters for the synthetic oils longer change intervals. Looking like that isn't the case. This is my first time switching over to synthetic also.
Old 11-17-2007, 08:50 PM   #6
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
You can always change just the filter and add a quart if you want the added insurance and/or information.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 11-18-2007, 09:45 AM   #7
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
I use Amsoil 10W-40 Heavy duty long change interval oil. I use their filters & change them every 6 months regardless of miles. I change the oil annually or every 25,000 miles which ever comes first. I like the stuff and have very high regard for its performance. I recently did a "re-gasket" job after 175,000 miles and the wear was minimal to non existant in all areas, so its doing a good job IMHO. Alway a joy to replace seals over metal!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 11-18-2007, 05:02 PM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
I wasn't aware of any recommendations for a filter change when switching to syn oil.I am on my first Mobil One fill (break-in took 12,000 miles on dino oil for some reason) and kept using Fram.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 11-21-2007, 09:38 PM   #9
neonlarry
neonlarry's Avatar
^Fram? thats the one filter not to use. As far as mobil 1 and K&N IIRC they are both made by the same company.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-22-2007, 12:14 AM   #10
SSC's76
No No
SSC's76's Avatar
The same company also makes super tech filters for wally world, ***** Labs. Wix is a good filter IMO a K&N is a waste but i have friends that wont run any other type of oil filter.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 11-22-2007, 06:29 AM   #11
MylilBowTie
Right turn Clyde
Same company's make different brands but there is also variances in those filters. That's what needs to be looked at carefully. These are older but still shows the difference in filters.
http://minimopar.knizefamily.net/oilfilterstudy.html
http://people.msoe.edu/~yoderw/oilfi...ilfilters.html
Anyone have more updated ones?
