Old 11-27-2007, 04:55 PM   #1
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
Let's talk headlights
Other than appearance, what is the difference between the 1988-89 twin headlights and the later composite lights?
Here's my '89 with twins......
1991 with composite headlights......
www.67HEAVEN.com
2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme)
1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme)
1967 Belair 2-door-post (project)
1967 Corvette 427/435 coupe (now 502/502 red road warrior)
67HEAVEN is offline   Reply With Quote
Old 11-28-2007, 05:09 PM   #2
CPNEJR
CPNEJR's Avatar
Re: Let's talk headlights
they don't look any different than my 88
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-28-2007, 05:31 PM   #3
I think, but not positive since the earliest I had was a stripper 92. The difference is the 88-98 dual headlights are Halogen sealed beam units, while the later composites use Halagen bulb that twist into in a housing assembly.
Hopefully some of those more knowing will chime in with this.
Old 11-28-2007, 11:09 PM   #4
Boog
laying low
Boog's Avatar
Not sure what you're wanting to know but I recently swapped the dull composite lamps on my 97 for the dual halogen sealed beams from an 88. It is a bolt in affair, no wire harness mods either. Just snap the grille out and 4 bolts remove the headlamp assembly. I did have to twist the prongs 1/4 turn on the low side lamps for the wiring plug to hook up but that's all. 30 minute job. I can see again!
I did this because: 1) I like the sealed beams betterj
2) glass lense will not dull
3) I did not want to have to sand and buff
the plastic housings once a yr to keep them up.
4) the aftermarket ones fall short and the OEM ones
are too expensive.
5) did I mention I like the sealed beams better?
See for yourself.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-29-2007, 03:38 AM   #5
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
I agree with Boog. I can't stand ANY type of plastic headlamp. I've yet to find one that has even half the light output of my old '81 sealed beam single bulb system.
They fog over, look like crap, and have so little output I keep checking to see if they are on. This has been on multiple vehicles from different manufacturers. Both Neons, the Silverado, Toyota, a rented Ford Escort, the Grand Marquis I drove as a taxi, the Dodge Caravan I had in Oregon, etc. Every single one of them had those damned plastic lenses and every single one of them I had to put auxiliary lights on them just to see the road. Every car/truck I've had that had the sealed beam bulbs in them have been fantastic at lighting up the road. One reason I was so quick to jump at the Blazer I got. Sealed beam all the way, baby.
[EDIT] Oh, and I had Silver Stars (tried everything, Silver Stars seemed to work the best, but still useless) in the Silverado. And its high beams (crossed over for simultaneous low and high beam) put out less than 1/3 the light on the road that my non-halogen sealed beams do on the 81 Custom Deluxe.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 11-29-2007, 07:09 AM   #6
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
Boog and Mickey_D,
Thank you both. You've convinced me to keep the dual headlight design that came with my '89. I had considered changing to the later design.
Your responses are examples of what every questioner is looking for -- information and opinion based on experience.
www.67HEAVEN.com
Old 11-29-2007, 03:30 PM   #7
Tinker1980
Boog, that GMC looks really sharp with those lights. And it doesn't cost $100 to replace them if you break one! If my '89 didn't already have them, I'd be poking around the scrapyards looking for a set.
Tinker1980 is offline   Reply With Quote
Old 11-29-2007, 04:54 PM   #8
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
I stopped by my local shop this afternoon and they happened to have two mid-'90s pickups inside.........a GMC and a Chevy. BOTH trucks had perfect examples of the dull appearance on the composite headlights.
Frankly, I never really noticed the difference before, but I sure do now. Thanks again.
www.67HEAVEN.com
Old 11-29-2007, 07:12 PM   #9
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
So, now that we've beaten the headlights to death, how about the taillights?
I got the '89 with these Euro-lights (which I don't care for)....
I'm leaning towards going back to the stock taillights, unless someone has a better suggestion.
Old 11-29-2007, 08:49 PM   #10
My 96, I had put euros on it when I needed to replace my messed up stock ones. I didn't mind the ones I had. After a while I like them more than the stock. I sure liked the price compared to the stock lenses.
Anyways here is what mine was with factory, then with euro.
BTW I kinda like the look of the white with euros on yours.
Old 11-29-2007, 08:51 PM   #11
Boog
laying low
Boog's Avatar
Yeah, leave those euro things to the imports. I'll have the big red lenses on mine thanks.
Boog
primer is finer
Old 12-01-2007, 02:23 PM   #12
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
I'd like to do this conversion on my '89, how do you do it?
TennesseeZ is offline   Reply With Quote
Old 12-01-2007, 06:25 PM   #13
neev_nav
Flying Dutchman
neev_nav's Avatar
What about these? They are more of an 03-06 style, but still red.
http://www.optionracing.com/features...sp?itemID=1561
94 Chevy Ext. Cab 4x4 350 (My baby)
"Women carpool. Men convoy."
neev_nav is offline   Reply With Quote
Old 12-01-2007, 08:58 PM   #14
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
Hey, now those I like. I'd like to see them on an '88-'98 stepside. Anyone got one?
Thanks, neev_nav.
www.67HEAVEN.com
Old 12-02-2007, 08:07 AM   #15
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
Anyone know who makes these beauties? I think they're the best alternative to stock that I've seen for these trucks.
www.67HEAVEN.com
Old 12-03-2007, 06:14 AM   #16
Kevin45
Kevin45's Avatar
Why not smoke the existing tails. You can either get Nightshade to spray them or mix up a little black with some clear and shoot them. That is how mine was done. And they showed up great at night. I am going to do the same thing to my '93 and get rid of the Euro's. And if your tails are the least little bit dull, by doing this will shine them back up.
'93 Silverado Reg. Cab Shortbox
.060 over 350 Quick and fun!!!
Kevin45 is offline   Reply With Quote
Old 12-03-2007, 10:31 AM   #17
neev_nav
Flying Dutchman
neev_nav's Avatar
I think I'm going to get the tails I posted above and smoke them. Just need some slightly warmer weather. (-18 here currently)
Old 12-03-2007, 05:02 PM   #18
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Where you at neev? Sounds like you're in my neighborhood.
Darrin
RIP ESLL
Old 12-03-2007, 08:37 PM   #19
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
I'm betting he's a lot closer to me.
www.67HEAVEN.com
Old 12-04-2007, 12:02 PM   #20
neev_nav
Flying Dutchman
neev_nav's Avatar
About 40 minutes north of Toronto, but we're all getting hit by the same system from the looks of it!
Old 01-23-2008, 11:51 AM   #21
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
neev_nav,
This post is to thank you for suggesting these lights. I think they look great on my truck.
www.67HEAVEN.com
Old 01-23-2008, 10:51 PM   #22
Pyrotechnic
Pyrotechnic's Avatar
Those are the best aftermarket tail lights I've ever seen. I don't think I've ever seen any that look better than stock but those look awesome.
Pyrotechnic is offline   Reply With Quote
Old 01-24-2008, 12:01 AM   #23
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
What do they look like lit up?
Old 01-24-2008, 07:22 AM   #24
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
Yeah. A lot better than the ones that were on it when I bought it.
www.67HEAVEN.com
Old 01-24-2008, 07:24 AM   #25
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
I won't know until later this week when I take it home.
