Old 03-11-2014, 10:41 PM   #1
mooseknuckles
mooseknuckles's Avatar
steering box/pump fitting size?
does anyone know what fittings I would need to convert the power steering hoses over to -6an braided hose?....what thread size? are they metric?...86c10.
mooseknuckles is offline   Reply With Quote
Old 04-07-2014, 05:12 PM   #2
mooseknuckles
Re: steering box/pump fitting size?
fyi...
Old 04-07-2014, 06:20 PM   #3
SCOTI
SCOTI's Avatar
My 89 used Metric o-ring style fittings. If that's what yours has, I can get the sizes @ my shop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
SCOTI is online now   Reply With Quote
Old 04-07-2014, 06:43 PM   #4
mooseknuckles
thanks...but I already got them, ones 18mm to -6an and the other two are 16mm to -6an. the fuel line quick connect I have will work on the pump side return line.
Old 04-13-2014, 10:49 PM   #5
mooseknuckles
done...
Old 04-17-2014, 02:36 PM   #6
terrylgreenjr
thats super clean
terrylgreenjr is offline   Reply With Quote
Old 04-17-2014, 07:50 PM   #7
mooseknuckles
Originally Posted by terrylgreenjr View Post
thats super clean
thanks!
Old 04-18-2014, 08:57 AM   #8
GEARBOXGARAGE
GEARBOXGARAGE's Avatar
Is that a standard AN hose on the pressure side? You'll need a high pressure hose assembly instead of the standard type that you would use for fuel. It won't handle the 1,500-2,000 psi of the power steering system. The return side is ok with that, as it is the low pressure side. Russell offers some components specifically for p.s., as do others. Just thought I'd check...
-Mike
Check out the Gearbox Garage Shop Truck build here: http://67-72chevytrucks.com/vboard/s...d.php?t=607718
Be sure to also check out our website at www.thegearboxgarage.com.
GEARBOXGARAGE is offline   Reply With Quote
Old 04-18-2014, 09:40 AM   #9
Hart_Rod
Hart_Rod's Avatar
Is there a particular part # for the pressure hose?
Hart_Rod is offline   Reply With Quote
Old 04-18-2014, 03:12 PM   #10
GEARBOXGARAGE
Depending on which brand you would like to go with, here are a few examples;
Russell Powerflex Hose: Stainless Braided Hose for High Pressure Power Steering Lines, Teflon inner liner, 308 stainless steel braid, -6 size, 2,500 max psi, 3' length, Part # 632600, use with Powerflex Endura Hose Ends.
Aeroquip AQP High Pressure Hose: Abrasion resistant fabric cover for long life, available in black or blue, Synthetic rubber inner tube, -6 size 2,250 max psi, 3' long only available in black, part # 1503-6-3, 6' long blue part # FCG0606
Earls Power Steering Hose: Abrasion resistant fabric cover, pretty much the same as the Aeroquip with ratings, I think they are both made by Parker, available in blue, 6' long part # 130606ERL.
Be sure to use the corresponding hose ends specific to each manufacture. We use the Aeroquip hose and Ends, but have also used the Russell Stainless braided. Depends on the look you are going for. I'll get a pic of the hose posted this evening. Fragola also makes a power steering hose, available in blue similar to Earls and Aeroquip. We can
-Mike
Old 05-04-2020, 07:15 PM   #11
howell57
Called Summit and told them what I needed and for what truck (1972 C10) power steering gear box 9Pressure side) and they sent me Russell 648030???
Are one or both (648060-648080) for a 72 C10?
TKX
howell57 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
