Old 05-14-2017, 06:01 PM   #1
87Flh
87Flh's Avatar
10 bolt to 12 bolt swap
I have an 87 R10 with a 10 bolt rear, I want to swap it out for a 12 bolt. Will any rear end from 73 to 87 interchange? If I find a 12 bolt from an earlier truck, will it be a direct bolt-in for my 87? Thanks.
87Flh is offline   Reply With Quote
Old 05-14-2017, 08:01 PM   #2
69heavychevy
69heavychevy's Avatar
Re: 10 bolt to 12 bolt swap
Yes its a bolt in swap, but you will need a conversion u-joint.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 05-14-2017, 08:11 PM   #3
bbbc10
Diggin The SquareLife
You have to worry bout how wide the rear end is from diff models just cant bolt it in an go
bbbc10 is offline   Reply With Quote
Old 05-14-2017, 09:20 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Explain please ? It sounds like you're saying that 73-87 there were different widths.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-14-2017, 11:28 PM   #5
oldpurple
I've wondered about this swap as well (but in the opposite direction). Would anyone know if the driveshaft length is the same between the two?
oldpurple is offline   Reply With Quote
Old 05-15-2017, 09:38 PM   #6
69heavychevy
They should be, I used a driveshaft out of a swb with a 10 bolt and used it on my 12 bolt. Donor truck also had a th350.
Old 05-16-2017, 11:28 AM   #7
87Flh
87Flh's Avatar
At this point I am just planning ahead, I want to change my gears and install a posi. The reason I am considering a 12 bolt is because a friend has a posi for one. I think I will be better off keeping my 10 bolt.
Old 05-14-2017, 08:12 PM   #8
87Flh
87Flh's Avatar
Thank you sir. I thought that was the case, just needed confirmation from somebody that knows these trucks better than me. Thanks again.
Old 05-14-2017, 08:13 PM   #9
87Flh
87Flh's Avatar
Are they generally wider than the 10 bolts?
Old 05-15-2017, 08:08 AM   #10
king-918
king-918's Avatar
I just grabed one. Mine hasn't seen the road yeat but it is bagged and i haven't had any problems
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-15-2017, 08:25 AM   #11
Jstock85
I was under the impression that they were the same widths as well.
Jstock85 is offline   Reply With Quote
Old 05-15-2017, 02:26 PM   #12
abig84
abig84's Avatar
autozone part# 3-3130 might be the combo ujoint you need. i ended up putting a 77 drivetrain into a 84 k5 blazer, used everything but the 12 bolt rear end so it might work backwards?
it gets kind difficult telling parts store guys that you need a universal universal joint so you can try that number and see if its the one you need
abig84 is offline   Reply With Quote
Old 05-15-2017, 06:53 PM   #13
Tom
driving is in my blood
Tom's Avatar
2wd vs 4wd might be different width, I know it is for 88-98's. That and the u joint, otherwise they bolt right in. Not really much stronger then the oem 10bolt though so I'm not sure the point besides bragging rights?
Old 05-15-2017, 09:38 PM   #14
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Tom nailed it on the head. The truck 12 bolt has a pinion shaft diameter of 1.438 and the 8.5 10 bolt has a pinion shaft diameter of 1.625 leading many to argue that the 8.5 10 bolt is actually stronger. I've had a 8.5 10 bolt that lived (a long life) in a low 10 second full steel body malibu that made over 700 from a stroked big block that also made crazy torque. I don't believe that going from a 8.5 10 bolt to a 12 bolt truck rear end is an upgrade. There is a reason that GM is still running basically the same rear in ever 1/2 ton vehicle they build.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 05-22-2017, 11:58 PM   #15
Damien
Damien's Avatar
I swapped the 10 bolt in my '83 for a 12 bolt from a '79 and only needed to change the U-joint. The U joint on the 10 bolt was actually larger than the one on the 12 bolt. In hindsight, I wish I would have kept the 10 bolt or swapped in a 10 bolt from a '91 'Burb with the larger axles.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 06-12-2017, 06:50 PM   #16
Pontiac1976
Pontiac1976's Avatar
If I remember right 82 up only have the 10 bolt.
73-81 you could get the 12 bolt
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
