12-23-2012, 01:13 AM | #26 |
But Found Her 25yrs Later!
Re: 62 Fan Shroud ???
Here's another pic I found:
12-23-2012, 01:21 AM | #27 |
60-66 Nut
The '63-'66's use a completely different fan shroud. You can buy them new from the aftermarket, or if you're real lucky, you can find a good used one.
http://www.classicparts.com/1963-66-...ctinfo/78-921/
12-25-2012, 11:43 PM | #28 |
Does this look like the original 62 radiator?
The reason I ask is my 62 shroud doesn't quite work with this radiator. It's like my radiator is about 1/2 too thick.
12-26-2012, 12:50 AM | #29 |
60-66 Nut
That appears to be an original '60-'62 radiator. I wonder if the shrouds were specific to the number of rows in the core?
12-26-2012, 12:28 PM | #30 |
I guess I'll add a spacer between that radiator and shroud.
I'll get some measurements and post them. I'm hoping to get others to post theirs for comparison. Either my radiator is a lot thicker than usual, or like you say; the shrouds were radiator specific. Posted via Mobile Device
12-26-2012, 05:15 PM | #31 |
I lined these three up for comparison.
It's hard to tell exactly, but they all look to have the same height mounting flange. Maybe the second pic's flange is a little taller. - Don't know.
12-26-2012, 06:21 PM | #32 | |
I ran into that same problem when I went to the 3/4-ton 4-core radiator, and had to find the right shroud. The other two shrouds didn't fit it. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
12-26-2012, 06:35 PM | #33 |
It could be I have a thicker radiator.
I took some measurements. The shroud sitting flat is 2-1/4" from mounting flange to barrel lip. . . And the Radiator is 2-3/4" thick from mounting flange to innermost surface. Posted via Mobile Device
12-26-2012, 06:40 PM | #34 | |
Do the shrouds for the heavy-duty Radiator look the same other than a taller flange? Posted via Mobile Device
12-27-2012, 12:46 AM | #35 |
60-66 Nut
Is your radiator a 4 row core Robert?
12-27-2012, 01:30 AM | #36 |
check on page one for my post with all three styles.
12-27-2012, 01:52 AM | #37 |
I just went and looked. 3-Row
12-27-2012, 02:04 AM | #38 |
The one I had back in the 80's was surely the barrel type. Posted via Mobile Device
09-29-2017, 03:41 PM | #39 | |
http://67-72chevytrucks.com/vboard/s...85#post8050385
09-30-2017, 06:55 PM | #40 |
Maybe i will get my metal trash can a make one. lol
04-15-2020, 11:58 PM | #41 |
I realized I never posted back.
I ended putting in about a 3/8" spacer.
