02-06-2018, 04:31 PM | #26 |
Re: DIY4X crossmember fitment
Awesome Trevor, that would be fantastic. I've also asked BlueBullet to measure his Longhorn. I will go back and triple check the measurement of mine as well.
Dan 1970 C30- 350/SM465 133" WB, Soon to be a K series 1970 C10- LWB 250/3OTT, (sold) 1966 IH Scout 800- 152/T-90/Dana 20/ D27s |
02-06-2018, 04:32 PM | #27 | |
02-06-2018, 04:45 PM | #28 | |
Right.. I think the frame should be the same height spanning the distance in between the lines below.
02-06-2018, 05:02 PM | #29 |
That measurement on mine is 5-1/8" on both sides. I measured right in front of engine cross member.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
02-06-2018, 06:20 PM | #30 |
So here's my solution for those interested. Kert offered to make me some shorter parts to fit my frame, but that costs $$$, I also could've had it cnc milled locally, but that also costs $$$.
Here it is as received from DIY4X I went to the shop and picked out my thickest chop saw blade And sliced the pieces in half, Here's my height after the cut, just about perfect. Now ill grind away some of that nice powdercoat, cut a V groove, square it up, and burn it back together with the Lincoln
02-06-2018, 06:40 PM | #31 |
Perfect!! That was going to be my suggestion if it came to it.
02-07-2018, 02:32 PM | #32 |
I will clamp them in place inside the frame and tack it together in a few places before I weld them up completely. That way it will guarantee a perfect fit.
