Old 12-10-2018, 11:03 AM   #1
pound41
old leaf springs
Hello
I have a pair of rear leaf springs that I bought 25 years ago. They have been sitting since then in my shed. I want to lower my blazer and remove the lift.
any reason not to use them. can springs go bad just by sitting
pound41 is offline   Reply With Quote
Old 12-10-2018, 04:12 PM   #2
cleszkie
cleszkie's Avatar
Re: old leaf springs
If the spring eye bushings look OK, I'd go ahead and use them. The only things that could damage a set of springs would be exposure to extreme heat like a fire, or expose to salt water like being submerged in the ocean for a long time. Heat from a fire will remove the temper from the steel and render them useless. Deep corrosion pitting will also weaken the springs. You are probably good to go.
cleszkie is offline   Reply With Quote
Old 12-10-2018, 04:52 PM   #3
pound41
Thanks for the reply. They have new eye bushings So i will go ahead and use them
