Old 08-30-2013, 04:26 AM   #226
burkey05
burkey05's Avatar
Re: What did you do yo your truck today??
took out the old smog pump and replaced it with a reman
1988 GMC c1500 SWB D/D RHD 5.7L 700R4
burkey05 is offline   Reply With Quote
Old 09-01-2013, 07:45 AM   #227
jmig
jmig's Avatar
Installed my hood struts and made a pattern for the sides of my trailer fenders.
Then transferred it over to some sheet metal and mocked it up for install.
jmig is offline   Reply With Quote
Old 09-05-2013, 10:05 PM   #228
TheAmazingNate
Size:  96.1 KB I added a nos gm tailgate decal to my bare cheyenne tailgate.
TheAmazingNate is offline   Reply With Quote
Old 09-07-2013, 07:40 PM   #229
burkey05
burkey05's Avatar
fabbed up brackets etc for some dual thermal fans
Old 09-21-2013, 07:08 PM   #230
70chevy10
70chevy10's Avatar
Painted my bowtie and grill inserts, polished chrome, and removed the brush guard
Before
Attachment 1154423
After
1970 c10 LWB (BIG BUILD UNDERWAY) SEMA 19?
1969 GMC K2500 V6 Step Side Long Bed
2008 F250 650hp CUMMINS SWAPPED Daily Driver + too much to list
LAST DROP GARAGE, LLC.
Check the Shop out!
http://www.lastdropgarage.com
70chevy10 is offline   Reply With Quote
Old 09-21-2013, 07:10 PM   #231
70chevy10
70chevy10's Avatar
Before
Check the Shop out!
Old 09-26-2013, 09:17 AM   #232
MaritimeDragRacing
MaritimeDragRacing's Avatar
Swapped rearends in my 2WD 1994 ECSB 1/2 ton. Mine had bad axle bearings and a LOT of backlash and was making noise for a long time. It was 3.42 open and the rearend I swapped in was out of a 2WD 1994 ECSB but it was 3.42 with a "gov-lock" posi. Only other difference between the two trucks was the body colour. Mileage was a lot different though - mine has 353,000 kms and the one I swapped in had only 124,000 kms.
http://www.maritimedragracing.com
Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information.
MaritimeDragRacing is offline   Reply With Quote
Old 10-02-2013, 08:11 PM   #233
jb1016
"Oh well, it's a driver."
jb1016's Avatar
New power steering pump...the 275s are a little hard to turn with no assistance.
Old 10-12-2013, 08:37 AM   #234
jmig
jmig's Avatar
Update from last weekends work on the truck, finished cutting my bed supports out of 2 inch schedule 40. Going to tack these in and pull the bed back off to fab up some lateral supports for the wheel wells.
Also picked up a set of shorty headers and removed the Y pips so shes lays as far as possible for now.
Old 10-13-2013, 04:28 AM   #235
burkey05
burkey05's Avatar
finished off the dual thermo's, seems to be working well. the summer months will tell
Old 11-03-2013, 09:50 PM   #236
Red88
Red88's Avatar
Last summer I was told by a mechanic that he couldn't align my truck because the upper control arm mount knockouts needed knocking out. They wanted $250 for the job, in addition to the cost of alignment. Thanks to this forum, I already knew what he meant and what the fix was. Yesterday I picked up a set of alignment cam bolts from Orielly's and put them in. Turns out PO had already done the knockouts and the problem was that one of the cam bolts was just rusted and stuck against the control arm mount. After some cursing, wrenching, and alot of PB Blaster got it free. Went ahead and cleaned up the mounts/control arms and replaced all the bolt/cams since I had them. Not a bad job at all with an impact wrench. Now for an alignment tomorrow.
Yesterday I also put helicoils in the transmission tail shaft replacing stripped transmission mount threads. Truck had no transmission mount bolts in it when I bought it. Again, thanks to this forum, I bought the right size bolts and installed them about a year ago. Felt a little mushy going in so I had doubts about the threads. You guessed it! Checked under the truck the other day and bolts missing again. Had to jack up the transmission, unbolt the crossmember, move it out of the way to get access to drill the holes out, use the tap from the helicoil kit, and install the helicoils and new bolts. Tightened down just fine!
Today I pulled the ECM, ECM mount, and Blower to do clean the a/c evaporator as described in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=410384
As described, with some patience, it was a relatively easy job although my evap was not nearly as nasty as some of the pics I've seen. The trick in getting the blower out was to turn it so that one of the flat edges nearest the power connectors on the blower was pointing up and pry it under the edge of the dash. Popped out without any breakage, used the spray foam condensor cleaner from home depot ($5) and rinsed with a garden hose spray nozzle, wiped everything down as best I could and put a new blower motor in (bearing was failing and noisy). Buttoned up, smells better, don't get a huge amount more air but definitely better than it was!
This pic, indicated by the tape measure, shows the edge to rotate toward the bottom dash lip to get the blower out.
This pic shows the view thru the glovebox opening with glove box, ecm, ecm mount, and blower motor removed
This pic show the evaporator after the foam/water cleaning treatment, there really wasn't much to clean out. I got lucky
Great weekend working on old red! Been thinking about these projects for quite awhile now so it feels good to get it done.
'88 K1500 Scottsdale
5.7 TBI, 5spd MG5
Red88 is offline   Reply With Quote
Old 11-04-2013, 12:16 PM   #237
billie64
billie64's Avatar
im doing my floor with sound control mat and eva sound deadener and heat shield kit thin it black carpet be nice when im done
billie64 is offline   Reply With Quote
Old 11-29-2013, 12:36 AM   #238
anthony1536
anthony1536's Avatar
well last week I fixed my lighter so now I can use my cell phone charger again. I also found that the tray my computer sits on was very loose., so I tightened it and tie wrapped the computer to it and so far it seems to have fixed my problem with one side of my throttle body on working right. just yesterday I had to replace the headlight switch and the pigtail the plugs into it. so its been a productive couple of weeks.
1989 Silverado long bed 350
anthony1536 is offline   Reply With Quote
Old 12-03-2013, 03:31 PM   #239
FrankieD
FrankieD's Avatar
Thought i would do a simple tire rotation yesterday because the front tires were cupped and pretty noisy, well it had McGuard lugs on it and as things go one will always be a ***** (it striped), so I took my trusty hammer and chisel and split it off and through the other 3 in the trash.
Ordered a new Radio and speakers off Amazon to day.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 12-17-2013, 09:22 AM   #240
FrankieD
FrankieD's Avatar
Added a front factory skid plate to the 94 that I removed from my K 2500 Suburban when I mounted the plow. the Sub also has the front carrirer and transfer case skid plate I will be removing when it warms up and transplanting them to the 94
Old 12-18-2013, 10:41 AM   #241
Gunner41
Gunner41's Avatar
Re: What did you do to your truck today??
Lets see. Went to change oil and found a leaking oil cooler line (lower) and replaced. Changed oil and found a leaking block (R/S headgasket) so today I will be removing my heads /intake and other such wonderful things and because im removing the upper Im going to replace my fuel rail/regulator and having my injectors cleaned and possibly replaced. Good thing my Christmas shopping is done.
Gunner41 is offline   Reply With Quote
Old 12-23-2013, 01:45 AM   #242
burkey05
burkey05's Avatar
changed the cab mounts today
the rubber mounts themselves were well worn, and the metal washers and spacers were all rusted
replaced with the energy suspension mounts
took about five hours
Old 12-23-2013, 01:51 AM   #243
burkey05
burkey05's Avatar
has made a definite improvement to handling and cornering
some more pics
Old 12-23-2013, 08:00 AM   #244
54 jimmy
54 jimmy's Avatar
removed the keyless entry I installed to replace it with a remote starter with keyless entry. that was yesterday. today is installing cab clearance lights.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 12-28-2013, 01:22 AM   #245
Cape Codder
Cape Codder's Avatar
Added two milk crates of bricks and a tote of sand to the bed. It's winter here now.
Bob
Cape Codder is offline   Reply With Quote
Old 12-28-2013, 02:38 PM   #246
scotts62
One day...
scotts62's Avatar
Bob
Scott
93 crew cab build
Project 62
Old 01-07-2014, 02:00 AM   #247
Cape Codder
I replaced my instrument panel lights with red bulbs to match the aftermarket stereo and made a floor mat from a Caddy trunk mat for the winter
Old 01-10-2014, 12:47 PM   #248
Dustinmk4
Bought it
96 Chev 3500 crew long bed 454. Came with a shell and 5th wheel hitch. 136xxx miles. The guy took very good care of in mechanically. Recent tranny, diffs and motor services. Recent brake job including master cylinder. Recent AC work/recharge. Basically all the little issues common with these have been addressed. New tires. Recipts for all the work he has done since 90K. Should drag my trailer pretty good.
Does have some body blemishes but thats no big deal. Need the driver door aligned possibly new pins, common problem. Anyone have a really good fix?
Dustinmk4 is offline   Reply With Quote
Old 01-10-2014, 01:38 PM   #249
Cape Codder
Nice looking truck it sure is a long one. To me the door alignment is a priority thing as the longer you put it off the more damage can be done to the hinges,striker and latch. If done soon it involves only pins and bushings a cheap fix. If you unplug the wiring harness and drive out the old pins the door comes right off but have a strong friend as it is very heavy. I do autobody for a living and do the doors by myself with a office chair that adjust for hight but they are some of the heaviest doors I have removed in 40 years.
Bob
Old 01-10-2014, 01:49 PM   #250
Dustinmk4
Bob
Thanks, yes it is a long one and turns like it but with pulling a trailer I would rather have the length so I get to tell the trailer where to go rather than the trailer pushing the truck around, pluss I have lots of "stuff" to haul when we go camping
Thanks for the tips, I am also a body guy although not working in the industry anymore. I can handle pins and bushings but it is so common on these that I was wondering if there is a better fix that will last longer, better hinge set from something else maybe?
