Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-06-2017, 11:54 PM   #126
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: NJ Suburban
Looking good Paul. Did you find the inner 1/4 pc. you were looking for? I just picked up 2 parts burbs and I will check them out to see if either has a decent pc. if you are still in need. Pending snow this evening may hang me up a little but i will check 1st chance I get if you do need it.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 01-07-2017, 10:59 AM   #127
Hart_Rod
Hart_Rod's Avatar
Re: NJ Suburban
Nice progress.
Hart_Rod is offline   Reply With Quote
Old 01-07-2017, 01:48 PM   #128
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Richard
Richard one is on its way from Randy500. Thanks for thinking of me!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 01-07-2017, 10:11 PM   #129
zicc1835
zicc1835's Avatar
Re: NJ Suburban
looking good
zicc1835 is offline   Reply With Quote
Old 01-08-2017, 04:14 PM   #130
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Originally Posted by Hart_Rod View Post
Nice progress.
Thanks guys!
Glad it is inside now so it can get some work done!
Paul
Old 02-06-2017, 09:49 PM   #131
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
More bodywork. With the mild winter here in NJ the usual 5 snowblower repairs a week I saw last year are non existent this year. The plus is lots of Suburban time in the garage.
The inner part 3rd door rocker that is part of the floor was a pain to fabricate. Glad I saved the entire roof of my original Suburban for sheet metal repair material. This weekend I'll paint everything inside with either POR15 or epoxy primer and then weld on the outer rocker and the quarter panel patch!
Paul
Old 02-09-2017, 07:09 PM   #132
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
All the treated rust and homemade patch panel primed with KBS. I need to collect the door from storage and re hang it before welding in the new rocker and lower quarter piece. I'm sure my storage garage isn't plowed out yet! We got about 8" here in NJ last night. I'm loving my garage heater!
Paul
Old 02-11-2017, 01:45 PM   #133
Average Joe
Average Joe's Avatar
Re: NJ Suburban
Nice work!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-11-2017, 07:18 PM   #134
zicc1835
zicc1835's Avatar
Re: NJ Suburban
staying warm making progress looks great Paul
Old 02-12-2017, 07:37 PM   #135
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
And more progress! Welded in the quarter patch. Once it is epoxy primed and seam sealed I'll weld in the rocker.
Paul
Old 02-12-2017, 07:45 PM   #136
richard2717
Re: NJ Suburban
Moving right along, looking good. I can't seem to find time to work on any of mine, too busy cutting up parts trucks.
Was this pretty much the bulk of the metal replacement or do you need to do driver side as well?
Richard
Members I have met.
Old 02-12-2017, 07:50 PM   #137
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Richard both front rockers still need to be done as well as the driver side lower quarter. There is still a long way to go! I got the rocker inner and outer panels but they will need a lot of fabricating since they are pickup parts. The door had to come out of storage so that I could match up the body lines. Spent all morning fussing with the alignment!
Paul
Old 02-12-2017, 08:11 PM   #138
Bigdav160
Bigdav160's Avatar
Re: NJ Suburban
I was going to say, the door alignment looked better than factory. Good job.
I should ask, does that patch have the bead edge or no?
I bought a slightly larger patch and it has the beaded edge but the rest of the wheel arch patch does not. I am trying to figure out how I am going to make it look right.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-12-2017, 11:25 PM   #139
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Dave the beaded edge matches the factory edge pretty well. I saw your post with your patch and the issues you are having. I think the wheel arch patch that LMC sent has the beaded edge but I'll have to check. Years from now I hope I have the patience to align the door again!
Paul
Old 02-19-2017, 02:51 PM   #140
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Got the panels welded in epoxy primed and seam sealed. Tomorrow I'll shoot the sanding primer. I've got some warpage in the rear quarter but I'm really happy with the panel fit.
Paul
Old 02-19-2017, 11:09 PM   #141
goldenburb
goldenburb's Avatar
Re: NJ Suburban
LOOKING GOOD Paul
post good notes cause Ill be needing all the reference I can find. lol
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 01-19-2018, 11:19 PM   #142
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Wow it's been a while!
Got some work done on the front right side this past week. It will get a coat of epoxy primer before the rocker goes on.
Paul
Old 01-19-2018, 11:22 PM   #143
zicc1835
zicc1835's Avatar
Re: NJ Suburban
looks good Paul i been making some progress myself ...you around this weekend come get my saw
Old 01-30-2018, 10:45 AM   #144
Csrock82
Re: NJ Suburban
Nice job on the repairs.
Csrock82 is offline   Reply With Quote
Old 02-04-2018, 06:08 PM   #145
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Thanks! Made a little more progress. The right side is done. Time to turn it around and work on the left side now!
Paul
Old 02-04-2018, 06:50 PM   #146
04ls1gto
Re: NJ Suburban
Paul
Looks great, how many hrs did you have in rocker replacement? All 3 of mine are gonna need to get done. Maybe next Winter
04ls1gto is offline   Reply With Quote
Old 02-04-2018, 07:12 PM   #147
Killer Bee
Killer Bee's Avatar
Re: NJ Suburban
great work Paul!! thanks for the recent chat, helped me out a bunch!
I chickened out though and found a very little rust Fremont burb a couple of hours from here..
seller and I worked out a real fair deal and I think we both did good..
I'll get a thread going sometime to share with everyone as I move out of 'ol rusty blue..
please keep up the good work in the fight against rust and keep us all posted!
Old 02-04-2018, 11:15 PM   #148
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
GTO I’ve got way to many hours in this. The front rockers are tough because you have to modify a truck rocker.
Paul
Old 02-17-2018, 02:22 PM   #149
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Getting ready to prep and prime the cowl and windshield area. The plan for the rust on the window frame is to treat and paint it with POR 15 and hit it with the Omni epoxy primer while the POR is still tacky. It's already been wire brushed with my 4" and die grinders.
Paul
Old 02-17-2018, 11:55 PM   #150
Average Joe
Re: NJ Suburban
Nive work!
I am dreading pulling my windshield. I know there is some rust. I just hope it doesnt require too much surgery.
