Old 07-27-2004, 02:21 AM   #1
68 Suburban
68 Suburban's Avatar
What are the symptoms of a Torque converter going bad?
Not on my truck, but on one of my cars I had noticed a sound that almost sounded like a rod knock, but it seemed to be coming from the trans. The car would go into gear and drive, but it had that knocking sound. Today, I was working on the engine and got it running well, but when I went to drive it, nothing. No forward, no reverse, no knocking. Any suggestions? thanks
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 07-27-2004, 02:29 AM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Check your fluid and your filter.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 07-27-2004, 06:59 AM   #3
BOSS
Just here to help
BOSS's Avatar
Was it changed lately?I just finished working on a tranny this weekend and we had to put a new torque converter on it to get it to run(they make 2 different splines for the 700r4 by the way),now that we have a new one in it shifts better then it ever did.
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 07-27-2004, 09:54 AM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
The Knocking could be a cracked flex plate, very common
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 07-27-2004, 10:01 AM   #5
cdowns
cdowns's Avatar
the first indication that a torque converter is goin bad is:
IT STARTS HOLDIN UP LIQUER STORES !!!
Old 07-27-2004, 11:30 AM   #6
ACES
Life is a gamble
ACES's Avatar
I think we all knew that someone was going to write that.
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 07-27-2004, 12:57 PM   #7
browndawg71
Unbolt The Converter From The Flywheel And Pry It Back Away From The Motor Start It Up If The Knocking Stops It Is The Converter. Dont Let It Run Long Because The Crank Can Rub A Hole In Converter Snout
browndawg71 is offline   Reply With Quote
Old 07-27-2004, 03:22 PM   #8
68 Suburban
I guess the first step would be to check the trans fluid....Doh!!! All is good now
Old 07-27-2004, 03:32 PM   #9
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
The most simple of things are sometimes overlooked!
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
