04-05-2006, 07:08 PM | #176 |
Re: Project Penicillin~ 68 crewcab build up!
unfrickenbeleivable. How much to have a cab done in primer???????
67- 72 Parts collecter |
04-05-2006, 10:31 PM | #177 |
Back in the sticks
Keep it up Kevin! And what is the body wax you are talking about shooting in the holes? Does it prevent rust? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
04-05-2006, 10:52 PM | #178 | |
Kevin LFD Inc. |
04-05-2006, 10:59 PM | #179 | |
https://www.eastwoodco.com/shopping/...emType=PRODUCT Kevin LFD Inc. |
04-06-2006, 05:28 AM | #180 |
English Chevy Owner
I've been using anti rust wax for years here in the UK where we know a thing or two about rust. There are several products on the market here, probably the best known is a product called Waxoyl made by the same company that make Hammerite paint, the second best known is called Dinitrol, who have a variety of different products depending on what you're doing with them and theres a new pretender from a company called Bilt-Hamber. I've used their water based deruster which is just magic, dissolve some non toxic non corrosive powder in warm water, soak the part for 24 hours and the rust all is dissolved away. They do a cavity wax that I'm going to try out when I've done the rockers on my truck. I'm also going to do the inside of the cab corners with it. The wax never quite sets so it's self healing, i.e. you get a small scratch in it and it will close up over it, just seals out water and oxygen from the steel.
These are some steel shutters from my french house that I derusted in Bilt-Hambers Deox-c, they were very heavily corroded, a quick blast over with a wire wheel in a grinder and then a 24 hour soak. rh is before middle after and the end one painted.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
04-06-2006, 08:54 AM | #181 |
Could you find any links to the different products you listed! And nice rock wall in the back ground!! With the body wax what do you use to apply? East wood has a kit that is kind of like a suction sprayer. It sucks the product out of the container and shoots it in thru a rod of flexable hose that I think will make it great for getting up into the windshield area!
Kevin LFD Inc |
04-06-2006, 10:12 AM | #182 |
looking good dude
04-06-2006, 10:20 AM | #183 |
English Chevy Owner
Waxoyl's website is here http://www.hammerite-automotive.com/waxoyl.htm
Dinitrol is here http://www.dinitrol.co.uk/ Bilt-Hamber is here http://www.bilthamber.co.uk/shoppingbasket.php Waxoyl comes in cans that can be applied with either a simple pastic pump and tube with a nozzle that fits straight on the gallon cans or it can be applied using a compressor powered gun, same with Dinitrol, the Bilthamber Dynax wax comes in a big aerosol with a built in tube. All of them will benefit from being stood in a bucket of hot water for a while to make sure the wax is as runny as possible, ideally you want a warm day to apply it on so the wax will flow into the nooks and crannys and joints, however do it out of direct sunlight, if a panel is too hot it'll just slide right off! Once it's set then its not a problem. It's a horrible messy job though, drive the vehicle onto a sheet of plastic that you can throw away afterwards, wear some really old clothes and a hat and just be prepared to pump a couple of gallons into all the box sections, inside panels and doors etc (drill holes if neccesary and then plug with little plastic plugs). I know waxoyl and Dinitrol also do an underseal type product in black or clear for use on the underside of the vehicle too.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission Last edited by Lippyp; 04-06-2006 at 10:22 AM. |
04-06-2006, 05:24 PM | #184 |
Lippyp~ Thanks I will check into this stuff. I am sure it is messy but well worth doing if you want to slow/stop the rust in these trucks. As for applying it this is one of the main reasons I designed the Tip & Flip dolly. My first cab was so bad (under a great paint job) that their was no saving it and I told my self I would not waist my time building one if I can not stop this from happening.
Kevin LFD Inc. |
04-07-2006, 01:22 PM | #185 |
Well I'm new to this site and happened across this project.
I have been working towards doing a crew cab out of a suburban for several years. I have cut down several rusted out 'burbs to learn how they were assembled. And I have already done many hours of dreaming along with that. And after looking at all of your pictures from your project there has been nothing that you have shown me that I already have not planned for. Though I was not looking at changing the 'burb roof line I was going to redefine the rear cab panel to match. I'm still mixed about which way to go now. The lower roof line looks better (like it should be done). I do have a couple of questions: 1) How did you work the roof line down did you cut the roof off at the drip rail and work it out or did you cut and splice it in middle? 2) I noticed that when you cut out for the 4th door that you removed the vin plate. I have been working with a local TXDot officer and he will not accept it with the vin plate tampered with. He looks at it like it is unidentifiable and considers it to be stolen. So do you have a plan about how it will be identified? Thanks for any input Brian '72 Chevy Cheynne L/B 1/2 ton (daily driver) '72 Chevy C/10 s/b, 1/2 ton (for sale) '72 Chevy Custom Deluxe 'burb, 3/4 ton '72 Chevy Cheynne 'burb, 1/2 ton (soon to be crew'd) '70 Chevy C/10, 1 ton, flat bed (shop truck) '72 Chevy Custom Deluxe 3/4 ton l/b (project) '66 Toyota Landcruiser '64 Olds Dynamic 88 (for sale) '67 chevy 3/4 ton, 4X4 l/b not running (for sale) many 69-72 parts trucks Last edited by tlcruiser; 04-07-2006 at 01:34 PM. |
04-10-2006, 05:57 PM | #186 |
Old School, New Style
Ttt
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
04-11-2006, 06:10 PM | #187 |
First off the roof was already done when it came to me. It looks likew they cut it off about 1.5" up from the rain gutter and slid the upper section down over the lower and welded it their. Not what I would have done but it is ok all the same.
As far as the VIN plate it was inspected by the proper people and documentation was taken for verifacation. I the vin plate will go back in but in the fourth door jamb again by the proper authoritys. Not an easy task but when you know people and spend the time asking before you just do it, it seems to help. Good luck with state! Kevin LFD Inc. |
04-11-2006, 07:33 PM | #188 |
Keep up the great work, man I lvoe this build thread
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
04-11-2006, 07:55 PM | #189 |
The door hinges are ready so I will be setting door gaps and starting on the pass side for rust repair soon. In the mean time I snuck a 2wd blazer project into the shop for a few days of work. http://67-72chevytrucks.com/vboard/s...d.php?t=194823 need to brake things up now and then
Kevin LFD Inc. |
04-11-2006, 08:07 PM | #190 |
Here is a picture of the door hinges that were bead blasted and new pins installed. If we get a warm day I can primer them.
04-12-2006, 12:55 PM | #191 |
Well it's good to hear that someone has thought about how to make a project legal.
I don't know how many times I have tried to tell people that they need to start by talking with DOT officers. Doing this in the beginning can save a lot of time & money. Been there done that. Heck they can be your friend or they can be your enemy, I want them on my side. Have you noticed that any of the newer 73-92 suburbans & crew cabs offer very similar rear door hinges? '72 Chevy Cheynne L/B 1/2 ton (daily driver) '72 Chevy C/10 s/b, 1/2 ton (for sale) '72 Chevy Custom Deluxe 'burb, 3/4 ton '72 Chevy Cheynne 'burb, 1/2 ton (soon to be crew'd) '70 Chevy C/10, 1 ton, flat bed (shop truck) '72 Chevy Custom Deluxe 3/4 ton l/b (project) '66 Toyota Landcruiser '64 Olds Dynamic 88 (for sale) '67 chevy 3/4 ton, 4X4 l/b not running (for sale) many 69-72 parts trucks '55 2 ton dump body grain truck Last edited by tlcruiser; 04-12-2006 at 01:04 PM. |
04-12-2006, 01:12 PM | #192 | |
Yes I have but the differance in door thickness creates porblems in getting the door to swing full open. Or you can get it to swing full open but your dor gaps are on the wide side. We just used stock 3rd door hinges and rebuilt them backwards! Hinge pin in from the bottom and then just mount it upside down Plus when this is finished we are going for a completly stock (as stock as it would have been) look with the conversion. Kevin LFD Inc. |
04-19-2006, 10:28 PM | #193 |
So is it wrong of me to be a bit happy that this one is not a true 4 door. They sure did a great job building it, I only hope our finished product is this nice but with 25% more door!! We will be starting back this weekend on the 68 crew cab project so stay tuned for more (over 100 so far) pic's.
Kevin LFD Inc. |
04-19-2006, 11:31 PM | #194 |
whats up with the grill in that thing. otherwise a great looking truck
common sense isn't so common anymore |
04-19-2006, 11:36 PM | #195 |
It looks like a 4 door in the picture with the rear door handle on the drivers side until you read the details of the truck. I wonder what frame he used or maybe used 2 frames to build it, he did not say in his description.
04-19-2006, 11:40 PM | #196 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
From the pictures it looks like they just lengthened the undercab portion on the frame with straight C channel steel?
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
04-19-2006, 11:59 PM | #197 |
anybody got a link to that one?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
04-20-2006, 12:01 AM | #198 |
04-20-2006, 12:08 AM | #199 |
Thanks!
04-20-2006, 01:21 PM | #200 | |
saving one more
You are definatly doing it the right way!
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
