Old 08-31-2010, 09:59 PM   #1
Truckbert-CS
Question Inline six parts interchange
Does anyone know if the intake and exhaust manifold from a 250 will work on a 292?
Some of the GM truck 250s had a two barrel intake, and I have a chance to pick one up.
What do you think?
TW
Truckbert-CS is offline   Reply With Quote
Old 08-31-2010, 10:05 PM   #2
garmar
garmar's Avatar
Re: Inline six parts interchange
I'm pretty sure my Dad did this with a 73 Chevy with a 250 I-6 he had. I also did a search and the manifolds show up as the same for the 230, 250, and 292.
Also, Pre-75 intake and exhaust manifolds are two separate pieces. After that they were made one piece. Do your manifolds unbolt or are they cast with the head?
garmar is offline   Reply With Quote
Old 08-31-2010, 10:34 PM   #3
Truckbert-CS
The one I saw was the separate exhaust and intake. I did some more searching and the intakes do show up like you say.
I was really interested in the exhaust because it was a 2 piece manifold. I'll check again tomorrow and pull them off if this is the case.
I just bought a 292 last week and am looking for options to dress it up a little.
TW
Old 08-31-2010, 11:43 PM   #4
raycow
AFAIK, no GM inline engines had the intake and exhaust manifolds cast as one piece. Some 75-up engines had the intake cast in one piece with the head, but the exhaust manifold on those was still a separate casting. I do not think the exhaust manifolds from the two different types of heads will swap, but I haven't actually tried it to find out.
250 and 292 manifolds (intake or exhaust or both) will definitely swap if both engines have the same type of head.
Ray
raycow is offline   Reply With Quote
Old 09-01-2010, 12:18 AM   #5
GRX
GRX's Avatar
You are thinking of the "integral head". Avoid these at all costs.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 09-01-2010, 01:03 AM   #6
garmar
garmar's Avatar
Ray
Exactly right. I meant to type the head and intake was cast together not the intake and exhaust. Sorry about the mistypo.
And yeah, they're junk. My Dad had to replace it on an old 75 Chevy he used to have with the pre-75 head and intake that wasn't integrated. It cracked IIRC.
Old 09-01-2010, 01:26 AM   #7
MudBug
MudBug's Avatar
250 and 292 share the same dress up stuff except for the side covers.292 has a taller side cover but you can get 292 specific covers.
MudBug is offline   Reply With Quote
Old 09-01-2010, 05:38 AM   #8
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
I have this.
And it just sux, Cant do anything to it. Besides maybe paint it.
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 09-01-2010, 10:53 AM   #9
raycow
Originally Posted by Mr79C10 View Post
I have this.
Just in case you didn't know.......
If you are having problems with one of those, it can be replaced with the earlier type head. No modifications are required other than linkage.
Ray
Old 09-01-2010, 01:09 PM   #10
GRX
GRX's Avatar
Ray
That and new manifolds of course. Did the conversion on my friend's work van several years back. Did I mention what an absolute bear it was to remove one of those monstrosities from a van? Yes, believe I did.
Have to chock that wonderful integral head to misguided cost saving attempts of the late 70's to early 80's. Most every one which came into my shop back then was cracked. And if not they certainly needed to be resurfaced.
Old 09-01-2010, 07:59 PM   #11
Twisted6
Twisted6's Avatar
You would be much better off in the long run to go pre75 head.Better intakes Even if you make your own like i did.And you can have a much better exhaust system as well.You can get the pre75 heads to breath better then 240 cfm.You can't do much with the 75&newer junk Ops i mean head LOL.
Twisted6 is offline   Reply With Quote
Old 09-01-2010, 09:03 PM   #12
Truckbert-CS
OK, after a closer look it was the integral head (Intake and head cast together.)
So I left it in the salvage yard. I found a few other misc. parts so the trip was not a total waste of time.
Still looking and learning....
Old 08-16-2017, 10:23 AM   #13
ricaltman
What were the symptoms of a cracked integrated head and where were the cracks?
ricaltman is offline   Reply With Quote
Old 08-16-2017, 11:41 AM   #14
GRX
GRX's Avatar
Worked with a lot of these for fleet service. Always acquired new head from GM since all used heads from the yards would be cracked. Typically external around the exhaust & intake areas. Easily visible. Need not magnaflux to see them. Cracks in the exhaust seat areas were fairly common too.
Old 08-16-2017, 01:12 PM   #15
ricaltman
Thank you. I cannot get this thing to idle. I've changed everything in the electrical/distributor/fuel systems including carb. All except fuel pump. I'm lost.
