Old 07-15-2017, 10:06 AM   #1
4oldcars
4oldcars's Avatar
Air Cleaner
I feel a bit stupid posting this, but - - -
I have a 350 in my 71 Jimmy with an early 50's air cleaner. An original one, not a reproduction and no adapter between it and the carb. Problem is, when I drive it the air cleaner spins/rotates clockwise (if that makes a difference). It turns until it hits the master cylinder, rubbing and damaging the air cleaner. Is there a simple cure for this? I have tightened it down as much as I dare and it still turns.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 07-15-2017, 11:37 AM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Air Cleaner
What kind of stud are you using to secure it to the carb? Is it rotating with the air cleaner? is the whole thing turning or just the lid? Maybe a pic would help? I have used a dab of blue loctite to thread the air cleaner stud into the carb itself, I had one that tried to back out every time I wanted to take the lid off and it annoyed me, so that was my fix.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-15-2017, 02:11 PM   #3
mikie 1954
Re: Air Cleaner
Maybe a gasket between the carb and cleaner would help? Just a thought, good luck .
mikie 1954 is offline   Reply With Quote
Old 07-15-2017, 03:45 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Air Cleaner
Vibration was causing the wing nut on mine to come loose. I placed a small rubber washer I made from a rubber hose and have been able to keep it secured this way.
As mentioned above a pic and an explanation on what is turning -the top or whole unit - will help.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-15-2017, 04:15 PM   #5
GRX
GRX's Avatar
That was going to be my suggestion as well. Surprising how often that ring gasket is overlooked.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-16-2017, 10:00 AM   #6
4oldcars
4oldcars's Avatar
Re: Air Cleaner
I like the idea of a gasket. I'll try that. This site never lets me down.
Thanx to all.
4oldcars
Driving:
The ones I let go:
