Old 02-14-2024, 06:20 PM   #1
fotoboy
350 wont shift out of first...
So... I have a transmission question... I have a 1980 Scotsdale with a (newly rebuilt) 350 and a (newly rebuilt) turbo 350 tranny.
It was shifting fine (beautifully actually), then I installed a manual choke kit on the QJ. Now when I drive it, it does not shift out of first, it acts like it wants to, or is starting to, then it lurches as if it were downshifting, which is bizarre.
When I manually put it in 1st, it doesnt malfunction, but will not shift to second if I manually shift it to 2nd. Thoughts?
Oh... Vac line is good and attached (i made sure it was clear, not clogged but didnt test otherwise), Modulator is new with rebuild...
fotoboy is offline   Reply With Quote
Old 02-15-2024, 04:01 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 350 wont shift out of first...
are you sure the new modulator is good.. ive seen several new in box parts be bad from the chinese factory.. and the rubber on the line ends is that in good shape?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-15-2024, 07:03 PM   #3
geezer#99
geezer#99's Avatar
Nice wheel pic but a pic of the motor might help.
geezer#99 is online now   Reply With Quote
Old 02-15-2024, 07:52 PM   #4
dmb
Active Member
dmb's Avatar
did you move the detent cable
dmb is offline   Reply With Quote
Old 02-15-2024, 10:51 PM   #5
v30crewcab
v30crewcab's Avatar
unhook the detent cable and try it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 02-25-2024, 08:00 PM   #6
fotoboy
yes, but completely replaced and adjusted it , also ran it without cable and it ran the same.
Old 02-25-2024, 08:00 PM   #7
fotoboy
check. no difference.
Old 02-25-2024, 08:01 PM   #8
fotoboy
fair enough. replaced the modulator and got same result.
Old 02-25-2024, 08:08 PM   #9
fotoboy
sure, I didnt think the engine photos would matter, dealing with the transmission...
Old 02-25-2024, 08:08 PM   #10
fotoboy
I also have a video if anybody thinks it would help...
Old 02-25-2024, 08:19 PM   #11
geezer#99
geezer#99's Avatar
Sure, play it.
Does your choke blade open all the way with the choke knob pushed in all the way?
Old 02-25-2024, 08:46 PM   #12
dmb
Active Member
dmb's Avatar
the detent cable ib not adjusted , it is all the way in , it would act like it was at wot all the time. pull up the plunger and hold the throttle wide open then push the plunger down
Old 02-26-2024, 10:33 AM   #13
fotoboy
Sure, play it.
Yes, but how does a choke effect the transmission?
Old 02-26-2024, 10:43 AM   #14
fotoboy
That is exactly how I adjusted it... (it is not the OEM cable) and is hard to see in the photo... (submitting new photo) but will double check that anyway. Thanks
Old 02-26-2024, 04:42 PM   #15
geezer#99
geezer#99's Avatar
Disconnect your manual choke set up and wire the choke wide open then test drive it.
Old 02-26-2024, 07:09 PM   #16
fotoboy
Ok, for fun I tried that, no difference what so ever.
Old 02-26-2024, 08:02 PM   #17
geezer#99
geezer#99's Avatar
Time to explore yours transmission warranty.
Could be governor.
Old 03-01-2024, 07:12 PM   #18
Shifty One
Shifty One's Avatar
It took me quite few to get one that works right....
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-02-2024, 02:54 AM   #19
Accelo
Accelo's Avatar
Sometimes the plastic gear on the governor shears. Pull the governor and check.
Accelo is online now   Reply With Quote
Old 03-02-2024, 08:45 AM   #20
Axle
Axle's Avatar
Do you have a metal line to your vacuum modulator (just rubber line for connections)? If not, the vacuum will suck the line shut.
Vacuum connected to a manifold vacuum source? If connected to a carb make sure you are not on a ported line.
You can drive a th350 with the kickdown cable disconnected (its not a tv cable like an overdrive trans). When you disconnect the kickdown cable does it spring/pull back towards the trans? (too tight if it does).
Axle is offline   Reply With Quote
th350 squareody
