07-16-2018, 09:09 PM | #1 |
Posi or not?
I have 3.08 rear gear in my 69 c10.
I want to go to 3.42. Do any of you not go to a posi rear end when you change gears? If so, did you regret it? |
07-16-2018, 09:13 PM | #2 |
Re: Posi or not?
I would ad the posi if it were mine.....but 3.42 is not much difference than 3.08....will depend a lot on your final trans gear and tire size...use a gear ratio calculator to determine your best options....http://www.csgnetwork.com/multirpmcalc.html
In your other post your talking about a ls/od trans swap.....a 3.73 or so will be much better with the od
07-17-2018, 11:32 PM | #3 |
Re: Posi or not?
Posi is fun and handy offroad. If you are getting inside the pumpkin for any reason, you might as well add it.
Only reason not to add is expense. Or if you're building a truck for a retired schoolmarm.
07-19-2018, 07:31 PM | #4 |
Re: Posi or not?
It depends on what you want to do with the truck.
for most normal driving conditions, a posi is not needed. If you want to burn rubber with both tires, then install a posi.
"Negative people always seem to have a problem for every solution" |
07-19-2018, 07:55 PM | #5 |
Re: Posi or not?
The one negative with a posi is that if you are in snow or ice, and your right foot gets really into it, the back end can come around more quickly and get you sideways.
But if you're careful with your foot it will be ok and better at keeping you going rather than being stuck with one wheel drive.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
07-20-2018, 11:36 AM | #6 | |
Re: Posi or not?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
07-20-2018, 12:06 PM | #7 |
Re: Posi or not?
"The one negative with a posi is that if you are in snow or ice, and your right foot gets really into it, the back end can come around more quickly and get you sideways."
Is there any other reason for having a posi ? |
07-20-2018, 12:11 PM | #8 |
Re: Posi or not?
Yeah, it lets you wear out your rear tires more evenly.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-20-2018, 06:48 PM | #9 |
Re: Posi or not?
3.42 are a 10% gear increase which really isn't enough to justify the expense IMO. 3.73 are a 21% change making it much more worthwhile, once again, IMO.
Not adding the limited slip would be a mistake (again, IMO!). I have a long bed 71 GMC that I used to drag my boat around the yard with and I added a posi and gears to it that were from my Jimmy's old 12 bolt. The added torque of the 4.11 really help and without the posi, it would get stuck in the yard sometimes! Everything I own has a traction device of some kind except my '03 BMW. It's only a $4000 car and it costs $2500 to add the LSD! I'm way too cheap for that...
07-20-2018, 08:17 PM | #10 | |
Re: Posi or not?
-klb
07-21-2018, 07:55 PM | #11 |
Re: Posi or not?
LOL. That was true of the IRS in my 240z as well, but the car was way more fun to drive when I swapped a Precision Gear clutch type LSD in it. Wish the beemer one wasn't so stupid expensive...
