Old 05-13-2017, 06:58 PM   #1
Oldtruckwelder
Oldtruckwelder's Avatar
Captive nuts
Working on bolting up doors on My 1957 stepside and most of the captive nuts are gone, some are easy to add nut and washer and to back up with wrench, some are not. thought it would be a whole lot easier if they were replaced.
Oldtruckwelder is offline   Reply With Quote
Old 05-13-2017, 08:27 PM   #2
joedoh
joedoh's Avatar
Re: Captive nuts
haha what a can do attitude! love it!
Old 05-13-2017, 09:54 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Captive nuts
awsome fix
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-14-2017, 02:14 AM   #4
mr48chev
mr48chev's Avatar
Re: Captive nuts
That is totally awesome. I think the missing or damage captive nut thing is one of those we all fight.
My ongoing truck projects:
Old 05-14-2017, 07:57 AM   #5
Oldtruckwelder
Re: Captive nuts
Originally Posted by Hubscrub View Post
awsome fix
Thanks guys,
The aggravation of trying to line up the doors is bad enough !!
Usually working as a one man show and trying to get to the back up wrench, and not a great supply to pick from online. And if you do find them the shipping is crazy to get them to the house.
The captive is a little different in hinge part that is furthest back that exits under the fender,still working on that one.
Old 05-14-2017, 04:41 PM   #6
Port&PolishMan
Port&PolishMan's Avatar
Re: Captive nuts
OK _ This Guy is up for the 110% Mac Giver - Award . .
Cool Fix !
Port&PolishMan is offline   Reply With Quote
Old 05-14-2017, 07:46 PM   #7
Oldtruckwelder
Re: Captive nuts
Sorry bad photo, plug welded in place.
Old 05-14-2017, 07:51 PM   #8
Oldtruckwelder
Re: Captive nuts
OK I apologize up front, but it kinda goes along with the subject matter.
Just saying......
Old 05-14-2017, 08:03 PM   #9
joedoh
joedoh's Avatar
Re: Captive nuts
yeeeowch!
Old 05-14-2017, 09:03 PM   #10
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Captive nuts
Oh my makes me hurt
Proverbs 3:5,6
Old 05-15-2017, 01:08 PM   #11
bowt1ed
Re: Captive nuts
Had a similar issue with the ones installed on my aftermarket replacement lower door pillars, but actually had the "cages" welds not hold - after welded in, of course. I replaced with regular washers and nuts and could reach all with wrenches, except the bottom one. I drilled a 1" hole in the front so I could get a socket in to tighten the nut, then installed a rubber cap to fill the hole.
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 05-15-2017, 01:24 PM   #12
MARTINSR
MARTINSR's Avatar
Re: Captive nuts
Awesome job, you rock! And thanks for doing such a nice tutorial, no really, you ROCK.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 05-15-2017, 01:25 PM   #13
MARTINSR
MARTINSR's Avatar
Re: Captive nuts
Just saying......
Poor little guy. Hope he got out of that mess ok.
Brian
1948 Chevy pickup
Old 05-15-2017, 04:30 PM   #14
Clarance J
Clarance J's Avatar
Re: Captive nuts
Hello guys. This goes back to early 2008. At that time my welding skills were not that good but I needed to get the doors back on my truck to make it drivable. I figured out a way to make it a no-weld needed fix. I did tack weld nuts on the back side but those could be left off. Just as a side note my welding skills have improved since then.
Good job there Oldtruckwelder.
Earl
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 05-15-2017, 07:53 PM   #15
Oldtruckwelder
Re: Captive nuts
Earl
Thanks Clarance,
That a really good idea with the threaded plate and would act as a stiffner for the door as well..
JT from SC
Old 05-15-2017, 07:59 PM   #16
Oldtruckwelder
Re: Captive nuts
Got the captive nut finished for the back of hinge that exits under fender.
Crude but effective. Hinges bolted up, so far so good.
Old 05-24-2017, 08:46 PM   #17
Oldtruckwelder
Re: Captive nuts
Once door was tight and stayed in adjustment was able to work on door to fender gap. A while back the fender end panel, door bottom and skin , and rocker panel were replaced. As they were all bolted up together all the gaps were fugly. Added wire edge to fender, lowered end of rocker, cleaned up door edge... starting to finally come together.
