Old 02-20-2018, 05:45 PM   #1
SnS C10
SnS C10's Avatar
Just acquired this 86 k2500 4x4 suburban!
Hey guys long time member. My name is Shaun. I recently traded a toyota corona I had for awhile for this 1986 suburban. its a 2500, 4x4. engine is a crate 350 from Goodwrench with im told 40,000 miles on it and same for the transmission which im told is a th400 although i have not verified this. The engine runs beatifully and sounds great with its dual flowmaster mufflers. its all stock as it needs to pass california smog which it has.
My issue at this point is there is a ticking/knock noise. While in Park it will make the noise but with the slightest raise in rpms, say 100rpm, the noise goes away. There is no noise while driving or revving. Seems to only be right around the park rpm. Kind of sounds like the flexplate tapping against the cover but what do you guys think? I didnt think it sounded like a catastrophic problem and if it were i believe i would hear it more often at different rpm ranges. Thoughts? heres a link to a video
https://www.youtube.com/watch?v=QQvgLrDh0fA
SnS C10 is offline   Reply With Quote
Old 02-20-2018, 05:47 PM   #2
SnS C10
SnS C10's Avatar
Re: Just acquired this 86 k2500 4x4 suburban!
a few pictures too
Old 02-20-2018, 06:20 PM   #3
KeithT712
KeithT712's Avatar
Couldn't be 100 percent, but i do know the newer 3/4ton (maybe 1/2 ton also) chevys are prone to the flex plates cracking and giving a similar tapping noise.
This might sound like a dumb question also but have you drained the oil to see what it looked like?
1995 GMC K1500 Suburban 6" Pro comp 35x12.50R17
LSXburb -Build- 1990 GMC Suburban 6.0 Lq4 4l80e np205 D60 14FF
1988 GMC suburban 350ci Sm465 D60 14FF 8" 39.5x15R15
1969 Pontiac Lemans 400ci Muncie 4 speed
2009 Pontiac G8 Gxp M6
KeithT712 is offline   Reply With Quote
Old 02-20-2018, 06:25 PM   #4
SnS C10
SnS C10's Avatar
i have checked the oil but not drained it. Just picked up the burb yesterday. it does look clean. if it was a rod bearing, i would hear it more often correct?
Old 02-20-2018, 06:31 PM   #5
KeithT712
KeithT712's Avatar
I would think so, does it have an oil pressure gauge? that appears to be reading properly? I would think an internal engine noise it would continue with raised rpms unless it was somehow oil pressure related. It looks like a nice rig btw, I'm a big fan of suburbans and envy you guys out west that can pick them up with little to no rust
Old 02-20-2018, 07:10 PM   #6
SnS C10
SnS C10's Avatar
Yes it has a mechanical gauge. Just got off the freeway and it’s idling at about 35 pounds
Old 02-20-2018, 07:23 PM   #7
KeithT712
KeithT712's Avatar
Originally Posted by SnS C10 View Post
Yes it has a mechanical gauge. Just got off the freeway and itís idling at about 35 pounds
Thats impressive, my 95 runs a little lower than that after everything comes up to temp. I would maybe pull the dust shield off of the trans and take a peak at the flex plate if possible
Old 02-20-2018, 08:58 PM   #8
Electricduane
Active Member
congrats, awesome! Now ditch the running boards haha
Electricduane is offline   Reply With Quote
Old 02-21-2018, 10:41 AM   #9
SnS C10
SnS C10's Avatar
strange to me how a slight increase in rpm in park/neutral/drive makes that noise completely disappear
Another questions, the ride on the front end is pretty stiff. Does this have anything to do with the 2 shocks per side in front? Is there a remedy for the stiffness? I thought i read that you can remove one shock per side. Is this advisable and if so which one do i remove?
Old 02-21-2018, 10:58 AM   #10
Edahall
The stiff ride on a 2500 4x4 is pretty standard. I just drive slower and get used to it.
1990 ĺ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 02-21-2018, 04:10 PM   #11
KeithT712
KeithT712's Avatar
I had an 86 K20 that had the dual shocks in the front and it was a rough ride also, Ive heard switching to just single shock set up makes them ride smoother but haven't experienced the change for myself. And what Edahall said could also be the case, 3/4 tons usually aren't known for the best ride quality.
If you were to remove a shock from both you would want to remove the outer shock(i believe) the inner would function the same as a single shock set up, if there is a spacer up top it would probably have to be switched to go inbetween the one shock and the frame. I can take some pictures of my front end later to show the single shock lay out if needed
Old 02-21-2018, 04:43 PM   #12
SnS C10
SnS C10's Avatar
thanks KeithT712 i would appreciate that!
Old 02-21-2018, 07:36 PM   #13
KeithT712
KeithT712's Avatar
Heres the pics from my set up(both of mine are the same way) I had been looking into an after market set up for mine but decided against it mostly because of possible clearance issues. Hope these help!
Old 03-08-2018, 06:29 AM   #14
Ryan Hubbard
I have a 1990 V2500 Suburban and I initially went to one shock in the front and saw a noticeable improvement in the ride quality. The next step I did was I did a set of 4" lift Deaver Springs (front and Rear Springs) and Bilstein 5100 shocks all around. This made a huge difference in the ride quality of the truck.
Ryan Hubbard is offline   Reply With Quote
Old 03-11-2018, 06:15 PM   #15
rideair
Sns C10,
Looks like I have your little brother, 1988 1/2 ton.
Hope you use yours as a DD like I do mine, you'll enjoy every minute of it.
Electricduane, I'm not going to ditch my running boards either. They help the old guy get in/out without wearing out the front seat. ;-)
Enjoy,
rideair is offline   Reply With Quote
Old 03-12-2018, 10:32 AM   #16
SnS C10
SnS C10's Avatar
Originally Posted by rideair View Post
Sns C10,
Enjoy,
nice looking truck! I go back and forth between driving the suburban and my 2009 toyota tacoma everyday. Currently the suburban is disabled though due to a leaky power steering pump. I did however get the tail lights and reverse lights working yesterday. Found out that my brights are permanently on for my headlights. The switch on the turn signal lever does not seem to be working
Old 03-12-2018, 10:44 AM   #17
Ski-me
Ski-me's Avatar
hi/low beam switch should be down on the steering column, just above the brake pedal. There is a metal rod that runs from that switch up to the turn signal lever....
This was the one I used on my 89':
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 03-14-2018, 02:10 PM   #18
SnS C10
SnS C10's Avatar
thank you for the info! I will check out the metal rod when i can free up some time.
Also, my turbo 400 trans does not down shift. In fact when in drive, it seems to upshift too early. For example i may be doing 20mph in 3rd gear and not be in any kind of power band for the engine. The wire coming out of the side of the trans is connected to the switch at the gas pedal. What could be going on here? Maybe the switch is bad? Can the shift speed/rpm be adjusted?
Old 03-14-2018, 02:42 PM   #19
Ski-me
Ski-me's Avatar
I'm not familiar with the TH400 but with a little research, it looks like there is some type of actuator/valve thing either on the carb or on the tranny itself. I was first thinking about adjusting the TV cable, but I guess yours doesn't have it (700R4 has one).
Bring to tranny shop. Sounds like there may be some adjustments that could be had....
- Jeff
Old 03-14-2018, 02:52 PM   #20
SnS C10
SnS C10's Avatar
From what I understood there is either a switch at the carb or at the gas pedal which is where mine is. Hoping that this is an easy fix rather than spending money at the trans shop
Old 03-19-2018, 09:26 PM   #21
Ryan Hubbard
You need to make sure you have 12 volts to the "switch" at the throttle pedal in the cab. It is actually a variable resistor and varies the voltage to the transmission based on throttle position and handles the upshifts and downshifts.
Old 03-19-2018, 09:46 PM   #22
SnS C10
SnS C10's Avatar
I did test the voltage and I have 12 volts at the switch with the key on and also 12 volts when I apply the pedal to the switch which activated the wire running to the switch on the trans
Old 03-22-2018, 11:16 AM   #23
SnS C10
SnS C10's Avatar
replaced the power steering pump yesterday and took it for a drive. The trans is not downshifting at all. Since I have power at the switch by the pedal, should i assume the switch on the trans is bad?
Old 03-22-2018, 11:34 AM   #24
kwmech
Switch inside the pan, or it somehow got unplugged internally. The switch does not control the shifting on a T400. It just controls the down shift when you stab on the pedal. (If teh governor is working correctly) Early up shifting could be a vacuum modulator out of adjustment, a small vacuum leak in the hose coming to the modulator or the governor out of calibration. I've seen the rear bushing in the trans walk out of the case and strip the nylon gear on the governor rendering it useless. Pull the 4, 5/16'' bolts out of the small steel plate (3x3) near the back of the trans and pull out the governor. You will have a slight amount of oil come out. If the gear looks good, look at the valve internally and see if it goes up and down when you move the fly weights.
If all that looks good, then move on to the vacuum modulator for an adjustment.
Actually try adjusting the modulator first, pull the vacuum hose off and with a small flat blade screwdriver go inside the hole and tighten the screw about a 1/4 turn then take it for a drive and see if it makes a difference, repeat as necessary. When you pull the hose off and get even a slight amount of trans oil, you've found your problem, replace the modulator then adjust
Old 03-23-2018, 01:18 PM   #25
SnS C10
SnS C10's Avatar
i did what you said except i bottomed out the screw then backed it off 1.5 turns. The burb does downshift now and shift slightly better but not anywhere near it should. Better though. Will try to screw it in a little more but its already almost bottom out. May be time for a new modulator
Copyright ©2000 - 2018, vBulletin Solutions Inc.
