Old 02-27-2015, 12:11 AM   #1
mattbert56
mattbert56's Avatar
1965 k20 Dana 44 closed knuckle question
So here's what I got. My 65 has the original 44 in the front with 4:56 gears. Yes I know that it's out dated. And yes I plan on changing it once I get more mulla. But till then I freshened it up a bit. My question is. If the bottom of the tires are closer together than the tops, does this mean my spindle is toast? Or the axle housing is bent. Or my king pins are bent? The bearingsame are fine. But maybe the shims on the kino pins aren't correct. It is only on one side. I have an old picture of the frame where u can see the slant. But any help would be awesome. I know that these are old and there aren't many left out there. Thank you.
mattbert56 is offline   Reply With Quote
Old 02-27-2015, 02:04 PM   #2
61K10
61K10's Avatar
Re: 1965 k20 Dana 44 closed knuckle question
did you put in new knuckle bearings (top and bottom) maybe the housing is bent?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-27-2015, 02:21 PM   #3
Mike C
Mike C's Avatar
Most likely the king pin bearing is bad. No need to do one but a set. And I think you will find that a later model disc brake 44 with ball joints will cost less than those bearings...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
72 240Z-2.9l L6, triple Del'Lortos, T5, 12mm R200 LSD
85 FJ1100 & 01 XR400
86 Kawasaki X2 & 89 SX650 w/PJS cylinder and dual carbs
02 GMC 2500HD 4x4 Duramax
Old 02-27-2015, 02:22 PM   #4
mattbert56
mattbert56's Avatar
Didn't do new bearings the old ones looked fine. I just soaked email in diesel and repacked with greese. I'm wondering if it would just be my spindle? That part seems more likely to bend of it were to hit something hard.
Old 02-27-2015, 02:24 PM   #5
Mike C
Mike C's Avatar
My only experience with closed knuckle axles is with Jeep Dana 25's and 27's. And the only time I've had camber issues was with bad king pin bearings. Seems unlikely that a spindle would bend as they are pretty damn stout.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-27-2015, 02:27 PM   #6
mattbert56
mattbert56's Avatar
Mike c thanks for the input. I have an axle that I'm lookin at sometime this weekend others off a 71. I think. It has 3:73s but needs a bit of work. I'm hoping to just keep the axle that in here for the time being.
Old 02-27-2015, 05:54 PM   #7
BLT gmc
The housing is super tough as are the spindles. The bearing may be in good shape, but what about the king pins. The external diameter of the kingpin could have been damaged from a previous bearing failure, and it would be easy to miss. Ask me how I know. Did the kingpin fit the inside diameter of the bearing snug? Bruce
BLT gmc is offline   Reply With Quote
Old 02-27-2015, 08:03 PM   #8
mattbert56
mattbert56's Avatar
Yea. The kingpin bearing was snug on the pin. I put the shims all back on as I found them. But I'm thinking that if I remove the shims it would allow for the bearing to seat a little better. They are tapered needle bearings after all.
Old 02-28-2015, 03:35 PM   #9
BLT gmc
Are the races in equally good condition? I could see a PO replacing the bearings, but not the races. This could cause a clearance/shim issue. Bruce
Old 03-01-2015, 05:21 AM   #10
mattbert56
mattbert56's Avatar
The races looked great from what I saw. It may just need new bearings and races. ..now just to find them... finding anything for these axles is a real nightmare and a half
Old 03-01-2015, 09:57 AM   #11
It's the axle tubes that can bend, but I've only seen them bent up, making the top lean in. I have damaged knuckles and replaced. But that was the arms that receive the tie-rod ends. The wheels smacked something hard and those arms stretched a bit. I was toed way out and you could see where they stretched. Didn't hurt the tie-rod a bit.
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
"Don't call me a rough cut country gentleman. I'm just a redneck"
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 03-01-2015, 12:43 PM   #12
BLT gmc
The king pin bearings are readily available at NAPA. Right off the shelf. Just have to have the right partman. I did a complete rebuild on my closed knuckle with in the last year. Bruce
Old 03-01-2015, 12:59 PM   #13
mattbert56
mattbert56's Avatar
Think you may be able to dig up that part number?
Old 03-01-2015, 02:06 PM   #14
61K10
61K10's Avatar
Summit racing has them and cheep. if your races are good the bearings are $5.95 a piece. new races are $4.95 and are China. Better ones out there of course. part # 11590 and 11520.
1961 chevy K10
Old 03-01-2015, 02:11 PM   #15
mattbert56
mattbert56's Avatar
65 K10 thank you so much man.
Old 03-01-2015, 02:41 PM   #16
61K10
61K10's Avatar
summit did list the same for K10 and K20 might wanna ck though.
1961 chevy K10
Old 03-01-2015, 02:53 PM   #17
61K10
61K10's Avatar
Rockauto.com has timken, national at a good price also. Quad 4x4 has kits with shims for more $$. when i did mine i just reused the org shims. you are supposed to use a spring gauge to test the pre-load if done correctly.
1961 chevy K10
Old 03-01-2015, 11:27 PM   #18
mattbert56
mattbert56's Avatar
Alright. I'll check on that soon.
Old 03-29-2018, 02:23 PM   #19
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
did you figure this out ? im looking to rebuild mine,.looking for tips, thanks
49 chevy 5 window 20 year project
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 gmc 305 v6 custom
72 k5 highlander blazer 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Matt's k5 is offline   Reply With Quote
Old 03-29-2018, 02:32 PM   #20
mattbert56
mattbert56's Avatar
This threads like 2 years old bud hah. Yea. It was the bearings in the knuckles. I cracked one during I stall. They have shims that prelid the bearings, pay attention the the quantity of shims per cap. Top and bottom. I believe. Been a while. I'd recommend finding an open knuckle. Better axle. Good luck.
Excuse all of the dents In my truck she's a real character.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
Old 03-29-2018, 10:33 PM   #21
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
well that's why I asked, you never posted your fix, I have another axle but want to keep the factory look, I can always switch it later but bearings are cheap
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Old 03-29-2018, 11:00 PM   #22
mattbert56
mattbert56's Avatar
Napa has em on the shelf.
Old 03-30-2018, 12:31 PM   #23
61K10
61K10's Avatar
Hay Matt --- warm up there yet?
1961 chevy K10
Old 03-30-2018, 12:36 PM   #24
mattbert56
mattbert56's Avatar
Hey buddy. It's starting to. But winter ain't giving up in Wyoming that easy. Here's our "spring" hah looking at moving the 65 out here this summer. How's life treating you out in the people's republic of California?
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
