Old 03-28-2018, 05:16 PM   #1
87Skier
87Skier's Avatar
Interior lights stuck on
My 89 Suburban's interior lights won't shut off. I tried slamming all the doors, messing with the door switches on every door but nothing seems to work except removing the wire from the fuse block. Also the rear passenger doors have never operated the interior lights.
Not sure where the issue is, but hitting a really rough road usually shuts them off temporarily before some more bumps makes them come back on.
I'm thinking there is an intermittent short somewhere, but don't know where to look. Any suggestions?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 03-28-2018, 07:13 PM   #2
franken
Re: Interior lights stuck on
Turn the headlight switch knob to the right a little.
franken is online now   Reply With Quote
Old 04-02-2018, 01:04 AM   #3
87Skier
87Skier's Avatar
Forgot to mention, it doesn't matter where the dimmer knob is. Turning it all the way down doesn't turn off the interior lights.
Old 04-03-2018, 12:19 AM   #4
1774btcrew
1774btcrew's Avatar
Maybe just try a new headlight switch?
1977 Crew Cab Shortbed with 4BT Intercooled Cummins Diesel and a 4L80E
AZPartsLocators on Instagram
1774btcrew is offline   Reply With Quote
Old 04-03-2018, 12:30 AM   #5
mongocanfly
I'd be searching for a necked or pinched wire...the door switches make the ground side of the wire circuit...if one of those wires is pinched or missing some jacket and grounded, the light will stay on....^^^but could also be the switch^^^
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 04-03-2018, 09:52 PM   #6
87Skier
87Skier's Avatar
That's what I was thinking. Was hoping someone on here had the same problem and there was a 'trouble' spot.
Old 04-04-2018, 03:27 PM   #7
Ski-me
Ski-me's Avatar
Yea, I'd check out the pin switches. Maybe change them out to new ones. I think they are reversed grounded or something. Just a little strange as I recall.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
