Old 03-08-2018, 08:38 PM   #1
1968k20
Can't Have Too Many Suburbans!
1968k20's Avatar
Dismantling A Suburban
So I have this one-owner 67k20 body that I need to dismantle(chassis is in the garage rebuilt). I found an almost rust-free body that I will put on the chassis. My question: where should I make my cuts for the pieces that I want to keep? The roof is dented,right-rear quarter panel is junk,windshield frame, etc. I have room to store the sheet metal for another project.
1967 White K20 Suburban 292 4spd one owner
1967 Red K10 Suburban 292 4spd
1968 Green C30 Dump Truck 350 4spd "Turpentine"
1971 Bronze K20 Suburban 350/700r4 Factory tilt,tach,buckets "Cupcake"
1972 Olive C20 Suburban 350/350 FOR SALE
1989 Blue K3500 Pickup 454/4 speed
1992 Black K1500 350/700r4 "Big Blacketry"
1968k20 is offline   Reply With Quote
Old 03-08-2018, 08:39 PM   #2
1968k20
1968k20's Avatar
Re: Dismantling A Suburban
Maybe someone could draw a picture for me and map it out?
Old 03-08-2018, 08:41 PM   #3
1968k20
1968k20's Avatar
Next
Old 03-08-2018, 08:44 PM   #4
1968k20
1968k20's Avatar
More
Old 03-08-2018, 08:47 PM   #5
1968k20
1968k20's Avatar
Next
Old 03-08-2018, 08:49 PM   #6
1968k20
1968k20's Avatar
What tools should I use? Easiest order to cut?
Old 03-08-2018, 09:00 PM   #7
LockDoc
The Original Thread Killer
LockDoc's Avatar
I would cut the panels as big as I could just to make sure I had all the useable stuff. Not sure how bad the top is or where it is bent but some of the crew cab guys could probably use the good parts.
I use a sawzall for most of my panel salvage but a cutoff tool works good in some places too. Just be sure and get a full face shield before you start.
LockDoc
Leon
Old 03-09-2018, 11:28 PM   #8
HO455
HO455's Avatar
Red face Re: Dismantling A Suburban
What I have done in the past is to cut the good panel pieces oversize as much as possible to make it easier for the body shop. To make quick work of this task rent a gas powered chop saw for the big straight cuts and the sawsall for the small and curved cuts. The sawsall blades you save should offset the rental cost substantially. Just a word of caution its best not to do this on Sunday morning at 7:00 if you like your neighbors.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 03-10-2018, 01:16 PM   #9
suville
suville's Avatar
Barn door or tailgate & hatch ?
suville is offline   Reply With Quote
Old 03-10-2018, 07:45 PM   #10
1968k20
1968k20's Avatar
Tailgate/hatch
Old 03-15-2018, 08:44 PM   #11
1968k20
1968k20's Avatar
I am going to start cutting tomorrow! I want to keep the firewall and floor pans. Where should I make those cuts properly?
Old 03-18-2018, 12:06 PM   #12
1968k20
1968k20's Avatar
Yesterday's progress...
Old 03-18-2018, 12:27 PM   #13
HO455
HO455's Avatar
Looks like you had a productive day. Now the big dilemma. To save the center floor as one piece or to separate into two pieces, the floor and the third door sill.? Most likely someone needing the flloor will also need the sill. But the sill alone will sell faster. Oh what to do????
Old 03-18-2018, 02:11 PM   #14
1968k20
1968k20's Avatar
I am going to save all of it for now, because my 71k20 suburban needs rust repair!
Next, I need to take the side windows out. I am sure that someone has done this. What's the easiest way? Would like to save the gaskets if I can.
Old 03-18-2018, 04:14 PM   #15
HO455
HO455's Avatar
I was unable to save mine due to the rear corners were too hard and ended up cracking. Maybe if I had tried from the inside instead on the outside I may of had better results. I recommend wetting them down for a couple of days with soapy water and/or WD-40 to help soften the rubber. I soaked my fixed 1/4 window seals for a week prior to reinstallation and it made a real difference. I have heard since that WD-40 will help too. It's definitely not a one person job. And if things go horribly awry there is a set of windows on C/L locally at present.
Good luck.
Old 03-18-2018, 06:33 PM   #16
1968k20
1968k20's Avatar
Good luck.
Thank you. I will try that.
Old 04-07-2018, 09:13 PM   #17
1968k20
1968k20's Avatar
Finished tearing her down today. I get my "new" rust-free body next weekend, so I had to make room! I will start a build thread soon.
Old 04-07-2018, 09:14 PM   #18
1968k20
1968k20's Avatar
222
Old 04-26-2018, 04:33 PM   #19
Ramiro0727
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Last edited by LockDoc; 04-26-2018 at 10:33 PM. Reason: WTB by non-Subscribing member....
Ramiro0727 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
