Old 04-05-2018, 09:15 AM   #1
Travisarmenta
Travisarmenta's Avatar
1972 K10/K20 SUBURBAN Lift questions
I'm throwing a set of 3/4 ton's under my K10 as well as a 6 inch Skyjacker lift
1: Will i need to do any drive-line modifications? I've heard that anything over a 4 inch lift will need some, but considering I'm putting a Dana 60 which has a longer housing and yoke(roughly 2 inches) longer than the GM 12 bolt i might be in the clear.
I'm also getting the runaround from vendors and skyjacker itself as far as kits go.
I plan on using the C260AKSS kit, but no one can give me a solid answer as far as what I can or can't pick out , I already have a Steering arm, I want to purchase different shocks, skyjacker tells me i cant get the kit without shocks, vendors just say they sell the leaf kit and nothing else, no extended brake lines or shocks.....
anybody have any luck purchasing a kit/ piecing together a kit that is budget friendly? say around $1000 give or take?
Thanks fellas.
Travisarmenta is offline   Reply With Quote
Old 04-05-2018, 09:19 AM   #2
b454rat
Re: 1972 K10/K20 SUBURBAN Lift questions
Talk to off road design. They will hook you up.
Old 04-07-2018, 02:34 AM   #3
RedRoad
RedRoad's Avatar
Love my 2.5 inch EZ rides on my burb. You will need both driveshafts, dont cheap out.
Here is a 6 in all spring kit under your budget, no shocks, no brake hose.
http://www.sdtrucksprings.com/index....oducts_id=2344
The cheap trick for front extended brake hose is to use 72 2wd as it is a few inches longer.
RedRoad is offline   Reply With Quote
Old 04-09-2018, 03:55 PM   #4
Travisarmenta
I looked into the Tuff Country ones as well, still trying to decide.
Ill update this as it goes.
Old 04-09-2018, 03:57 PM   #5
Travisarmenta
Thanks for the info on the 2wd brake lines, i had no idea
Old 04-09-2018, 04:31 PM   #6
sweetk30
sweetk30's Avatar
go tuff country for best bang for the buck . . . skip rough country as there stiff ride crap . there is a reason there stuff is so cheep .
77-k30lb BIG truck build .
79-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
