Old 03-23-2014, 12:55 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Need help with measurements please, single vs. double wall side window dimensions...
I believe the side window openings for a single vs. double wall top differ in size. If anyone has a single and/or double wall top with the windows out, could you post the dimensions of the aperture: front to back and top to bottom?
I've tracked down a set of slider windows and suspect one of the two top designs needs to have the opening widened to accommodate the windows. A difference may also in part explain why there are separate gaskets for the two tops.
Thanks!!
Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, AASmedic, SoCoC10, Lumaestas, carbuff382
Old 03-23-2014, 07:21 PM   #2
DAVERJ
Re: Need help with measurements please, single vs. double wall side window dimensions
thought they were the same,i have both here can measure and post tomorrow
DAVERJ is offline   Reply With Quote
Old 03-23-2014, 08:27 PM   #3
jaros44sr
jaros44sr's Avatar
Geez, i thought they were the same size, and the differance was in the thickness of the fibreglas top
Guess well have to wait till tomorrow
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
Jim
jaros44sr is offline   Reply With Quote
Old 03-23-2014, 11:45 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks guys...I'm really curious.
Old 03-24-2014, 08:42 AM   #5
Bentblazer
Bentblazer's Avatar
I think this has been debated before, not sure if there was a clear answer. My top has one gasket and window from a double wall and one gasket and window from a single wall, I cant tell the difference.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Bentblazer is offline   Reply With Quote
Old 03-24-2014, 09:36 AM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
No difference in size or thickness. Just had all mine replaced with custom cut glass. Used the old double wall glass for templates. Fits perfect in the single wall top.
Tom Vogel is offline   Reply With Quote
Old 03-24-2014, 09:59 AM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The glass is the same but I suspect the openings have slight differences (3/8"?) in size. GM did make separate gaskets and this set of installation instructions for a NOS slider window I found indicates that one of the two styles needs the opening enlarged, which suggests that the sizes do differ. As shown, one gasket style is offset from the other relative to the wall. I'd like to know if I need to plan for enlarging the opening to do a slider install beforehand (in my case into a single wall top). The diagram illustrates the differing gasket configurations and glass relation with regard to the wall of the top(s).
Old 03-26-2014, 08:00 AM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
bump
Old 03-26-2014, 04:29 PM   #9
truckster
truckster's Avatar
I have had both gaskets. The aftermarket gaskets I have seen are all the "S" type gaskets, although you can still get the "H" type, as it's used in heavy equipment.
truckster is offline   Reply With Quote
Old 04-03-2014, 03:08 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks - The single and double wall gaskets are both available per Wes Hepp (Classic Heartbeat). Previously only 2x wall gaskets were available.
Bump for the measurements.....anyone?
Old 04-03-2014, 04:01 PM   #11
SS Tim
SS Tim's Avatar
Parts manual is showing four glass part numbers (two tinted and two clear) along with two different gaskets.
SS Tim is offline   Reply With Quote
Old 04-03-2014, 11:59 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Huh....four glass numbers, two tops, clear vs. tinted. That implies differences in the glass for 1x vs. 2x tops.
Old 04-14-2018, 10:55 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Reference pic shows single wall glass (thin) adjacent to double wall glass (thicker).
Copyright ©2000 - 2018, vBulletin Solutions Inc.
