Old 04-16-2018, 12:14 AM   #1
dtkarst
Trying to get one rolling again...
My nephew has been on me to get my old 61 Apache 4x4 running. He's 8 so I figured he'd forget about it and move on to something else...and he hasn't lol Its still all original, 235 inline that i can't get started. I would like to get an HEI for it, but imposture what I need. Can anyone post a link or any information on putting an HEI in it and where to get one? Trying to make it easy to work with. Let me know if anyone has any info. thanks
dtkarst is offline   Reply With Quote
Old 04-16-2018, 12:21 AM   #2
shp4man
shp4man's Avatar
Re: Trying to get one rolling again...
You know, points and condensers worked perfectly well for 60 years. Just sayin'
Anyway, does it have spark, compression and fuel?
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 04-16-2018, 12:32 AM   #3
dtkarst
Replaced them all, not have no spark. New cap, points, condenser, plugs, wires, rotor. Zero spark, so while I'm replacing the ignition and wires and such to it, I'm doing an hei if i can. Makes life easier. She's definitely not the first old pickup I've brought back to life, and I've used points and HEIs, and if i can do an hei, ill take it over points any day lol
Old 04-16-2018, 07:34 AM   #4
62 Barnfind
62 Barnfind's Avatar
Did you place the coil? Also are you getting power to the coil?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 04-16-2018, 10:40 AM   #5
SkinnyG
SkinnyG's Avatar
My '61 sat for twenty years. Fuel pickup/lines were plugged (ran off a jerry can to get it running), and the points were corroded enough to not actually ground (scuffed with sandpaper).
While I bought a kit for the carb just in case, the carb runs just fine as it is.
Nostrildamus - 1961 Apache, soon to go under the knife
The Crusty Chevy - 1977 Silverado, shortboxed & dropped, potato-potato.
SkinnyG is offline   Reply With Quote
Old 04-16-2018, 01:33 PM   #6
Short 3/4
Got the HEI for my 292 from Langdons many years ago and has worked great ever since
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 rear 4.10
Short 3/4 is offline   Reply With Quote
Old 04-16-2018, 01:34 PM   #7
dtkarst
Carbs redone, and I’m going to put an hei in it. Has a new coil, I’ve tracked it all down to a distributor. So if I’m going to get a new one I’m going to put an hei in it. I’ve been tinkering with it a few years here and there and ran through everything that was done before again this weekend. Just needing info on if anyone has done an hei in them and where to get one etc. thanks
Old 04-16-2018, 03:06 PM   #8
raidmagic
raidmagic's Avatar
Do you have power to the coil while cranking?
raidmagic is offline   Reply With Quote
Old 04-16-2018, 03:06 PM   #9
raidmagic
raidmagic's Avatar
Washing your clothes at the river on a rock works too but I bet you have a washing machine.
Old 04-16-2018, 04:51 PM   #10
shp4man
shp4man's Avatar
These old 6 cylinder engines don't need a 70,000 volt spark to run correctly. The only difference between an electronic ignition and points is the points require maintenance/replacement every 25,000 miles.
It wont make a 6 cylinder truck run any better, in fact, it may run slower than an old points distributor because when HEI came out in the mid 70's, they needed to chop the timing curve a bit to comply with smog laws.
Chopped timing= less power.
Now if you have a performance motor that turns over 6000RPM, it's a different story.
I work with automotive electronics all day, so for me, it's a joy having a vehicle with NO electronics.
As far as the OP is concerned, they never made an HEI 235, so he may be out of luck, but there may be some trick I don't know. There's always Pertronix.
Old 04-16-2018, 08:18 PM   #11
Cris
Google this:
hei for 235 inline 6
There are lots out there. Caveat Emptor though because most of these are imports. I would recommend buying one from a place with a phone number and the appearance that they will support you after the sale.
Cris is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
