Old 02-02-2016, 02:32 PM   #1
waco
292 I6 to 4.3 V6 engine swap
Morning to everybody:
After 4 days of searching (2 here & 2 via google) I have not been able to find the answer to the question of how to mount the 4.3 to the '79 P10 chassis.
I have a 1979 Chevy P10 with a 292 I6 (froze solid) with a TH350 transmission & would like to replace it with a beefed up 4.3 V6, I have the complete wiring harness & computer, that I have I the back corner of the garage.
This is just going to be a weekend fishing rig, so I don't see the need to stuff my 327 into it.
From the bell housing to the rear end I see no problems, but the problem I can not find a cure for is, how do I mount the engine to the frame short of making my own mounts. Is there a bolt on solution to this problem? I am drawing a blank on this one.
Thanks for any & all responses
Andy
waco is offline   Reply With Quote
Old 02-02-2016, 08:07 PM   #2
geezer#99
geezer#99's Avatar
Re: 292 I6 to 4.3 V6 engine swap
How's the 292 mounted?
If it's side mounts you likely only need to move the passenger side forward.
The 4.3 is just a 305 with the front 2 cylinders lopped off. Mounts are in the same place as any smallblock.
Old 02-03-2016, 12:45 AM   #3
Captainfab
60-66 Nut
The 4.3 V6 has the engine mounts farther back towards the transmission than a small block.
You might be able to use a set of typical V8 mounts and move them back with a plate under the bottom bolted or welded to the crossmember.
I do know that the 4.3 was available from the factory in a '86 K10. If it was also available in the mid '80's C10's a set of those mounts would be what you need.
The 4.3 V6 has a 4" bore and a 3.48" stroke, the same as a 350..........
Old 02-03-2016, 02:14 PM   #4
waco
geezer#99
If anything if moving a mount would do it, I think I will need to move one back, because the engine mounts are closer to the bell housing than on the V8's. But moving it back might work.
Captainfab:
When you say a plate under the V8 mounts, is that to be used as a spacer? I was wondering if the frame might be based on the 1 ton chassis for these little boxes. It did appear to be a little taller than my '70 at that point.
Thank You both for your responses
Andy
Old 02-04-2016, 12:47 AM   #5
Captainfab
60-66 Nut
Sorry I wasn't clearer. The plate I mentioned will be needed to support the bottom of the engine mount brackets as they will no longer be 100% on the crossmember. The plate will need to be bolted or welded onto the crossmember. You may also need a gusset or two on the bottom against the crossmember. This is basically what GM did on the '88 & up trucks with the 4.3 V6.
Old 02-04-2016, 02:13 AM   #6
waco
Captainfab:
Got it now. Did not think about the angle of the mount at the bottom where it mounts to the cross member. And gussets will most diffently be needed along with the bottom plate for strength.
Andy
Old 02-04-2016, 11:51 AM   #7
slotard
Just a heads up, if you're somewhere that requires smog every other year you need to swap ALL the emissions stuff from the donor vehicle to get signed off by a BAR ref. I believe the donor has to be no older, and maybe the same class of vehicle (not sure on that one).
Not what you asked, just don't want you to do a bunch of work to end up with something you can't drive.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-04-2016, 02:57 PM   #8
waco
slotard:
This rig was transferred between family members & will never have to see a smog check station. Where I am at, when you buy it, it is checked & never has to see a smog check again until you sell it out of family.
Thanks for thinking about me thou
Andy
Old 03-27-2016, 02:24 PM   #9
waco
Continuing my research on this engine swap
I seen a picture posted by DirtyLarry on 3/23/12 (sorry I don't know how to move it) showing 4.3l mounts in a '93. I thought I might be able to use those frame brackets on my '79 crossmember, with miinor modifications, to mount the 4.3l into the '79. This would keep the parts darn near all stock.
Anybody have any thoughts on this idea.
Andy
Old 04-08-2018, 08:40 PM   #10
waco
Well it has been awhile (family matters) but it is done. Moved stands to rear, front hole to rear hole. Made & installed 2 brackets from stands to front crossmember. Finally opened up 2 holes in trans crossmember & were done.
Many thanks to geezer#99 & Captainfab fortheir help.
Andy
Old 04-08-2018, 09:44 PM   #11
Bigdav160
Bigdav160's Avatar
What have you done with the exhaust? IIRC, 4.3L truck manifolds interfere with the frame
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-09-2018, 04:54 PM   #12
waco
The motor I am using is out of an S10 4x4 Blazer. The exhaust manifolds exit high at the bell housing & engine connection. I will start with the stock crossover pipe which exits down the passenger side. The engine also came with a set of headers which also connects to the crossover pipe. We will see about the headers. Good luck
Andy
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
