Old 03-31-2018, 10:46 PM   #1
'65 chevy lover
TH400 help
I have a TH 400 that I just got in my truck and, it's not shifting right. Could it have to do with this (see pic below) is this supposed to be hooked up to a vacuum line?
'65 chevy lover is offline   Reply With Quote
Old 03-31-2018, 10:50 PM   #2
B. W.
B. W.'s Avatar
Re: TH400 help
Yes, vacuum modulator. Hook it to vacuum & see if it shifts better.
B. W. is offline   Reply With Quote
Old 03-31-2018, 11:05 PM   #3
Captainfab
60-66 Nut
Re: TH400 help
Just to clarify, it needs to be connected to manifold vacuum.
Old 04-01-2018, 12:03 AM   #4
'65 chevy lover
Re: TH400 help
Thanks, will do.
Old 04-01-2018, 12:05 AM   #5
'65 chevy lover
Re: TH400 help
Thanks, Captain, I'll check it out.
Old 04-01-2018, 10:45 PM   #6
YoungPup1977
YoungPup1977's Avatar
Re: TH400 help
Just some additional tidbits.......From the pic, I believe the modulator maybe adjustable as well....so you can take a small screw driver and adjust the set screw in the modulator....turn the screw clockwise will firm up the shift (later) and counter clockwise with soften the shifts (earlier) ....
YoungPup1977 is offline   Reply With Quote
Old 04-02-2018, 12:23 AM   #7
'65 chevy lover
Re: TH400 help
Thanks, I'll check it out.
Old 04-05-2018, 11:39 PM   #8
'65 chevy lover
Re: TH400 help
Hooking up to vacuum fixed the problem. It shifts good now. I felt and looked around on the valve body, but didn't see or feel a screw to adjust how it shifts. Thanks to all for the help!
Old 04-06-2018, 12:37 AM   #9
Captainfab
60-66 Nut
Re: TH400 help
The adjustment screw on a vacuum modulator is inside and accessed thru the port for the vacuum hose.
Old 04-06-2018, 10:22 AM   #10
Alex V.
Alex V.'s Avatar
Re: TH400 help
This. And on a Turbo 400 the modulator is the sole control of shift points and firmness, except for the electric switch for WOT downshifts which most, but not all have.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 04-06-2018, 03:24 PM   #11
'65 chevy lover
Re: TH400 help
Ah, I'll check it out. It shifts fairly quick from 1st to 2nd, but from 2nd to 3rd takes a bit longer. I'll have to drive it more to see if I need to adjust it. Thanks for the info.
Old 04-06-2018, 03:33 PM   #12
mattfranklin
mattfranklin's Avatar
Re: TH400 help
Glad you got to the root of it. I'll bet it revved way up and then slammed the 1-2 shift. I had that vacuum hose fail once because the PO put the exhaust too close to it and burned the hose until it was extremely brittle.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 04-06-2018, 03:42 PM   #13
DieselSJ
Re: TH400 help
Be very careful and make changes 1/4 to 1/2 turn at a time. You can puncture the diaphragm in them if you crank it in too far. As me how I know...
87 R30 CC Dually, 454, TH400
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 04-06-2018, 08:48 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: TH400 help
Also there was a steel line that ran down there from the factory. Attached at the intake behind the carb and to the modulator with a 4" piece of rubber hose. A long rubber vacuum hose going all the way down there can weaken and colapse.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 04-08-2018, 12:21 AM   #15
'65 chevy lover
Re: TH400 help
Thanks to everyone for the information, it is very appreciated!
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
