Old 04-06-2018, 04:58 PM   #1
SunSoaked
SunSoaked's Avatar
Squares w 2-piece driveshaft
Looking for info on a 2-piece driveline setup. I need to go that route after a trans/t-case swap in my 85 longbed. Any pics w/o the bed or underneath would be great. Looking to see how the carrier bearing is mounted and if it's on a bracket or a separate x- member.
Thx in adv.
SunSoaked is offline   Reply With Quote
Old 04-06-2018, 06:57 PM   #2
mongocanfly
Re: Squares w 2-piece driveshaft
the one on my truck is mounted on its own crossmember...
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 04-06-2018, 07:13 PM   #3
SunSoaked
SunSoaked's Avatar
Is it the same height as the t-case output shaft? Does that first shaft run parallel to the ground? Where does the slip yoke go? Sorry for all the questions. This was an issue o hadn't thought about until the 11th hour.
Old 04-06-2018, 07:24 PM   #4
Tiger Joe
On our 79 c30 the slip yoke is the rear shaft to front shaft.
Our carrier bearing is almost directly at the back of the cab.
Yes front shaft runs parallel. All the angle is in rear shaft
I can prolly get pics tomorrow if you need em
Tiger Joe is offline   Reply With Quote
Old 04-06-2018, 07:25 PM   #5
mongocanfly
the slip joint in mine is at the hanger bearing..the spline section of ds goes thru the hb....there is a little down angle on the first section of ds to hb,,but not much...from hanger to rear diff the ds is down angle as well....mines 2wd,not 4wd , but the same applies to both...is your missing?
Mongo...aka Greg
Old 04-06-2018, 07:26 PM   #6
mongocanfly
maybe thisll help...it has some ds and hb pics...http://67-72chevytrucks.com/vboard/s...d.php?t=677974
Mongo...aka Greg
Old 04-06-2018, 07:31 PM   #7
mongocanfly
perfectly level is not good...it needs some angle in ds to keep the u-joints lubed...the angle in the joints keeps the needles moving around in the cups...
Mongo...aka Greg
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
