Old 04-08-2018, 07:02 PM   #1
sweetk30
sweetk30's Avatar
th400 tail housing spacer ?
this is a pic of the old 700r4 to th350 swap kits . the big aluminum spacer took up the difference .
i am in need of a spacer for a th400 with male on 1 side and the female on the other side . just a straight up spacer . this would be 1" - 1 1/8" thick range .
i have a combo i need to bolt up but cant just use a re-drilled round pattern adapter on it . so the spacer would be fast / easy / work good. and i dont want to tear apart the good working trans just to change a tail shaft and i dont have the tail shaft i would need anyway .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is online now   Reply With Quote
Old 04-08-2018, 09:13 PM   #2
YoungPup1977
YoungPup1977's Avatar
Re: th400 tail housing spacer ?
I read your post four times, not sure exactly what you are asking.....you dont want to spend the money to buy the correct output shaft (dont want to tear down a "working" trans) but you are looking for a spacer that may exist or may not...am I even close ? you want one end to bolt to the end of the th400 case with 6 bolts and the other end is bolting to what ? Help me help you....Thanks
YoungPup1977 is offline   Reply With Quote
Old 04-08-2018, 11:34 PM   #3
Captainfab
60-66 Nut
I believe what he is looking for is just as he said. A spacer for the tail end of a TH400 that is 1" to 1.125" thick. It would just fit in between the TH400 trans case and the transfer case adapter. I'm thinking he has a good 2wd TH400 and he wants to bolt up a transfer case to it.
Old 04-09-2018, 01:46 AM   #4
kwmech
Never seen a T400 spacer like you describe, having one made will cost more than swapping the shaft
Old 04-09-2018, 06:59 AM   #5
b454rat
Believe north west fab has something. It's posted on CK-5. At the cost of labor rates anymore, it would prolly be cheaper to get a spacer made. I had one made years ago and with material cost me $200. And was thicker than what he needs....
b454rat is online now   Reply With Quote
Old 04-09-2018, 07:23 AM   #6
sweetk30
sweetk30's Avatar
yep just a spacer .
the only real trans shop left in my area i would trust wants a min of 250 bucks just to install a basic shift improver kit and i supply the parts . . .
so i would hate to ask the price of a tear down / tail shaft swap / buy the shaft to install / and hope it still works after all this .
so yes a spacer makes sense .
took a round pattern np205 off . want to bolt up a np203/205 doubler . and long story short i cant redrill the face of the np203 to a round pattern and do it this way like most other guys do .
Old 04-09-2018, 11:10 AM   #7
YoungPup1977
What would it cost him to have this spacer made ? It appears its all about the money here....
QQ
Old 04-09-2018, 03:41 PM   #8
YoungPup1977
[QUOTE=sweetk30;8233885]yep just a spacer .
took a round pattern np205 off . want to bolt up a np203/205 doubler . and long story short i cant redrill the face of the np203 to a round pattern and do it this way like most other guys do .[/QUOTE
I understand your needs, itís to bad that in your area shops have to charge as much as they do. The VB would have to come off on a T400 to change the output shaft wihich jacks up the price. Here in the south we donít charge that much. My shop would charge only 100 bucks to change out the output shaft on a T400 plus it would work right when itís completed. Maybe you need to get some new friends who can do this work on the weekends. Have fun !!!!
Old 04-09-2018, 11:52 PM   #9
Captainfab
60-66 Nut
I'm not sure what the cost would be but probably half of the cost would be in CAD design and programing. Of course once that is done, producing multiple parts would be more cost effective. That might be something to consider if there was a possibility of other people wanting/needing this spacer. Selling these spacers to recoup some of the initial costs.
QQ
Old 04-10-2018, 07:51 AM   #10
sweetk30
sweetk30's Avatar
got a old friend who said under 200 bucks he can make me a spacer no problem .
Old 04-10-2018, 07:58 AM   #11
YoungPup1977
Once you have this spacer made, post a pic of it so we all can see it...before and after installation. Can't wait to see it....
THANKS !!!!!
Do you know the guys at eagle Transmissions in Elmira ? I am not sure if Bill is still there rebuilding transmissions there or not....
Old 04-10-2018, 05:41 PM   #12
sweetk30
sweetk30's Avatar
THANKS !!!!!
will do on pics for sure .
and do NOT get me started on that shop . he is a A #1 A$$ hole. . . and yes he is still open . and just as grumpy as ever . long story for another thread some time on the crap he tried to pull on me . lets just say if he did what he said he was going to do I would not of had to bring the trans back before install . and when I called him out on his lie's he got super mad .
Old 04-10-2018, 05:52 PM   #13
YoungPup1977
I didn't mean to get you fired up, i know the guy and I understand.... Good Luck on your spacer design and build....Have Fun....
Old 04-10-2018, 06:55 PM   #14
sweetk30
sweetk30's Avatar
ah we good . . . i just telling my super short version of the story .
my line of work i have to see him every now and then to give him stuff. so i keep it short and to the point.
were u at in nc ? i lived in kernersville for around 7 months .
Old 04-11-2018, 01:08 PM   #15
YoungPup1977
Cool ��
Old 04-12-2018, 09:41 PM   #16
sweetk30
sweetk30's Avatar
all mocked up and ready for the 1 inch spacer i have being made .
Old 04-18-2018, 09:00 PM   #17
sweetk30
sweetk30's Avatar
we have the spacer .
cost me $140.00 plus 2hr round trip time and under 20bucks in gas .
fits like a glove and spaced it perfectly for full spline engagement and a little play to boot .
and yes thats 3 shifter levers for the transfer case SYSTEM .
Old 04-19-2018, 12:07 AM   #18
Captainfab
60-66 Nut
Looks like it will work just fine. Is the triple stick part of the doubler kit? Who's doubler kit did you purchase?
Old 04-19-2018, 07:38 AM   #19
sweetk30
sweetk30's Avatar
offroad design tripple stick shifter / shift rails for 205 / doubler kit . 100% super quality stuff.
Old 04-19-2018, 07:43 AM   #20
A1971Blazer
A1971Blazer's Avatar
here's one I did for a buddy of mine...mocked up for final assembly
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 04-19-2018, 08:25 PM   #21
sweetk30
sweetk30's Avatar
only thing i can say is nice work . but think about a pivot point for the rear output rail like ord does . makes it shift smother and not try and bind up .
Old 04-19-2018, 09:11 PM   #22
sweetk30
sweetk30's Avatar
and if you want CRAZY incab shifting try this one i did for 1 of my trucks .
still have to tweek it just a hair .
center yellow = lokar for 4l80-e with bell crank kit to get linkage lined up and working 100% cause i have it mounted so far forward .
5 lever = winch in/out / pto hydro pump / 203 range box / 205 rear / 205 front .
i want to see some inner city criminal try and steel this one at a 7/11 parking lot and drive it away
Old 04-20-2018, 06:23 AM   #23
b454rat
Criminals? In ur area? Stop!! Lolol
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
