Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-10-2018, 09:57 PM   #1
GM man
GM man's Avatar
Fans and AC don't wanna mix
This is driving me crazy. I have a Vintage Air system and I'm trying to hook up the trinary switch to my fan relays. My PCM sends a negative signal to the fan relays to turn them on at the set temperature. I've spliced into those wires to send a negative signal when the AC gets to the set head pressure but the truck doesn't like that at all. It's actually killed the engine. As it turns out, I've got 12 volts on that leg (PCM to fan relay) until the PCM signals the fans to come on and then the leg becomes a ground. The PCM isn't putting out 12v on that leg, I'm sure it's coming from the relay, but I can't figure why it will take the ground signal from the PCM but not from the trinary switch. Any ideas? Here's the fan hook up diagram, with the PCM taking the place of temp sensor:
1972 GMC Jimmy 6.0/4L65
1972 Chevrolet long bed 1/2 ton
GM man is offline   Reply With Quote
Old 04-11-2018, 12:11 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Fans and AC don't wanna mix
Are you running the PCM control to 85 or 86 of the relays? if it's 86 and the relays are diode protected you may be getting the 12 volts from the relays through the diodes.
Just a thought.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-11-2018, 08:50 PM   #3
GM man
GM man's Avatar
Just a thought.
Well.. The PCM is on 86. I reversed 85 & 86 and had the same result. Tried a couple of other relays and the same thing. I'm getting 12v on that leg which doesn't make sense to me, but I hooked it up and it's working now. Before I soldiered it together, I was just touching the wires together to ground it and it sparked and killed the engine, which really confused me, but it seems to be working like it should now 🤯
Old 04-12-2018, 11:26 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The inner workings of the vehicle computer is a little above my pay grade so I would have to say that the polarity change you mentioned is hard to comprehend unless they use gated diodes or logic circuits. The bottom line is that it is now working for you and congratulations on that.
VetteVet
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
