Old 04-11-2018, 09:53 PM   #1
Jered1987
Jered1987's Avatar
Electric choke to manual
So my 350/350th combo in my k10 has an electric choke i have no computer for it i understand that it is a one wire electric choke how do I wire it in without a computer? Or any suggestions on a new carb without electric choke for my 350?
Jered1987 is offline   Reply With Quote
Old 04-11-2018, 11:40 PM   #2
Captainfab
60-66 Nut
Re: Electric choke to manual
What year of truck? What carb? To my knowledge none of the carburated trucks in the '80's had any sort of computer. Some had the ESC but I don't know that it had anything to do with the choke. If the choke has only 1 wire then all you should need to do is connect it to a fused ignition controlled 12V.
Old 04-12-2018, 01:08 AM   #3
truckster
truckster's Avatar
The electric choke (even on the computer-controlled Quadrajets) was not connected to any computer. It's about as simple as wiring gets - all you need is a +12v wire that's hot when the ignition is on. The choke is grounded through the carb body and heats up electrically. They're very dependable.
If I didn't build it or fix it, it's probably not mine.
truckster is offline   Reply With Quote
Old 04-12-2018, 06:44 AM   #4
b454rat
Why do you need a choke? I loved Canada for 2 years, drove a 78 Malibu with a 400 and never hooked up the choke. Got to -40 couple times, pumped it twice and fired up. Now wouldn’t stay running, but couple minutes of light revving and it stayed running.
Old 04-12-2018, 04:38 PM   #5
Dead Parrot
A lot of the electric chokes also involve the oil sender to keep the choke from drawing power when there is zero oil pressure. One less thing to drain the battery when the motor isn't running.
Dead Parrot is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
